SS/SC Injectors
Old Aug 23, 2007 | 08:13 PM
Blood Lucky Picnic's Avatar
SS/SC Injectors
I noticed alot of ppl recommending swapping out the stock injectors on 2.4ls and swapping them with the SS/SC injectors. What kind of gains are we looking at by doing this?
Old Aug 23, 2007 | 08:16 PM
sick06cobalt's Avatar
I have the stock ss/sc injectors... im looking to see what all is involved with switching them out... because i know nothing when it comes to the engine "internals" I know the gains are alright..
Old Aug 23, 2007 | 08:51 PM
krenfro88's Avatar
sick06cobalt we can do it together, i plan on buying mine soon
Old Aug 23, 2007 | 08:54 PM
XM15's Avatar
The injectors won't give you gains neccessarily; installing the SS/SC injectors will help keep your IDC in a good range if you have full bolt-ons and a tune. Other wise your duty cycle may be too high without the upgrade.
Old Aug 23, 2007 | 09:20 PM
mike25's Avatar
youl need hpt and need to know how to setup injectors....
Old Aug 23, 2007 | 09:42 PM
REDFOCZ's Avatar
Not true, I have full bolt on's and my IDC's are fine. I had to tweak the tune but it brought the duty cycle down to 81% at the top of third gear. The injectors will not hurt anything, but you do not need them.
Just get a tune and watch them fall
Old Aug 23, 2007 | 10:42 PM
rlinden86's Avatar
i have them aswell. there fine afrs can still be adjusted with a good dyno tune. you need hpt. a fuel line bleeder or some sort of tube to drain the pressure off the fuel rail. i think a small set of sockets and pliers some oil for lubin the o rings on the new injectors. the duty cycles will be changed in hpt.
you midaswell up the speedo to 145. the a good tune i can send you my tune file which is a physcostevo file and its for manual trans. its setup for the ss sc injectors header o2 sensor shut off which you can turn back on. speedo to 145 and rev limeter to 7k. if you have any questions pm me i got all the stuff and info if needed.
ryan.
Old Aug 23, 2007 | 10:56 PM
REDFOCZ's Avatar
Even if I wanted to run that tune, I couldnt. Steve is useing 2.1.18 I am useing the Beta I cant see his tune. Plus as I just said I dont need injectors my IDC's are only at 81%
I'll admit, stock the IDC's are really high but after adjusting the tune, there really is no need for them. Until you really get into engine or F/I. And my tune is set for my car, I really dont want a tune from across the contry on a differnt car.
Old Aug 23, 2007 | 11:00 PM
Jimmys2007CobaltSS/C's Avatar
i have the ss/sc injectos for my s/c setup....
Old Aug 23, 2007 | 11:03 PM
rlinden86's Avatar
understandable i didnt want to run that route either but to save money i had to at the time.
ryan.
Old Aug 23, 2007 | 11:08 PM
REDFOCZ's Avatar
I would hope so
ryan.
True, but make sure you check out all the values. make sure teh tables for the numbers in the Inj vs flowrate are right. And you will still have eto dail in the tune even after it has been loaded on the car to nail down the MAF.
Old Aug 23, 2007 | 11:10 PM
rlinden86's Avatar
I would hope so
yeah i didnt do much with the hpt just watched and learned a bit so. the the fuel flow is key and duty cycle i beleive.
ryan. i think im only at like 75% or something
Old Aug 23, 2007 | 11:13 PM
REDFOCZ's Avatar
So you are running the tune now?
Old Aug 23, 2007 | 11:17 PM
rlinden86's Avatar
ive been running my tune since may and its just a hare rich not to much could be dyno tuned to perfection but its great put down about 174whp.
ryan.
Old Aug 24, 2007 | 11:02 PM
JohnyNFullEffect's Avatar
seems like everyone is jumping on the injector swap band wagon. i too ordered the 2.2L cavi harness and bought redline24's injectors. < 1500 miles he said. after a custom vector tune, i am hoping to see good gains too.
Old Aug 24, 2007 | 11:20 PM
u got a decent amount of mods there johnny how much to the wheels??
Old Aug 24, 2007 | 11:22 PM
i'm working on it . last time i dyno'd, before most of them, it was at 165 to the wheels. let's see if i can break 175 with all the stuff i want.
Old Aug 25, 2007 | 02:10 PM
BennyHHR's Avatar
REDFOCZ is pretty much on the money here.
You can count on ZERO gains from the injector swap! Why?
The factory tunes go pig rich on a hard pull, approaching 10:1. With that the IDCs will get high.
The "fix"? Not bigger injectors! For best power on a N/A engine you want the PE AFR to be in the 12.5 - 13.0 range. AFRs around 10 will lose power! Tune the engine to get the PE AFRs in the proper range and two things will happen: 1. More power! 2. IDCs will be fine, as REDFOCZ has found.
Old Aug 25, 2007 | 06:18 PM
why not do the s/c swap like me and pjk91 and g5mike
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
