Stock MAF switch
Stock MAF switch
Im thinkin about switchin my stock MAF sensor on my 2.4 with a stock silverado sensor. The stock silverado sensors are blow through, I hear they work better. Anyone tried it, Is it compatible with my car? Will it even help?
our MAF sensor is also used on the Z06. That alone should tell you its not exactly a restriction point. Also, with that being said, I wouldnt be suprised if the same MAF was used on the silverado you're referring to. Im sure GM would like to use as few MAF sensors as possible, and would use the same one on as many cars as they could to cut production costs
pfft. You know how boring the 2.2 section is? I make more posts in the LSJ section than anywhere else, and the 2,4 secion next (mostly due to all the "2.4 supercharged build" threads)
I help everyone, everywhere
...at least i try to
Sl0wbaltSS
Nov 21, 2018 11:11 PM
