Supercharger swap Qs
I know I know, sorry for the newbness, I've been searching build threads but still have some questions to confirm. I've been referencing back to this old thread https://www.cobaltss.net/forums/how-...through-80620/ and looking at newer threads with updates.
This is going on a Saturn Aura 2.4 LE5, so I'll take care of the front mount and IC plumbing. Tuning, injectors, MAP, vac lines, intake with filter, throttle body I'll take care of.
Main concern is putting the supercharger on the engine itself.
Q1 - Rather than do anything custom, I read I can just use the LSJ tensioner and pulley, and cut one rib off the LSJ belt. Does the tensioner bolt up, no drilling and tapping required?
Q2 - The alternator will run in reverse but it still puts out a charge just fine?
Q3 - LSJ oil dip stick required?
Q4 - Is there a bracket that goes underneath the LSJ intake manifold/intercooler or does it just bolt to the engine?
3) No. you can use stock one and bend to your wishes.
4) There is a bracket and it is part of or attaches to the HE pump bracket
you need stage 2 belt junior
look at becks build, and hunterkillrs build
beck, me, hunterkillr, bunch of others...rock the lsj idler and tensioner with 1 rib cut
you must use the stage 2 belt
you need to grind a bit of the head to make tensioner fit, but no biggie at all
My le5 alternator has been fine, been boosted for over 40K miles, and I daily it
no, but if you can get one cheap enough, it just looks nicer...i still havent gotten around to putting a lsj one in mine
there is a bracket, 2 bolts that bolt to block then 1 bolt that goes to intake manifold(behind alternator-ish. is also part of the heat exchanger bracket
ThoR294
10-04-2015 08:44 PM
z28addiction
09-28-2015 12:03 AM
