Supercharger swap Qs
Old 10-30-2014, 06:14 PM
Overkill's Avatar
I know I know, sorry for the newbness, I've been searching build threads but still have some questions to confirm. I've been referencing back to this old thread https://www.cobaltss.net/forums/how-...through-80620/ and looking at newer threads with updates.
This is going on a Saturn Aura 2.4 LE5, so I'll take care of the front mount and IC plumbing. Tuning, injectors, MAP, vac lines, intake with filter, throttle body I'll take care of.
Main concern is putting the supercharger on the engine itself.
Q1 - Rather than do anything custom, I read I can just use the LSJ tensioner and pulley, and cut one rib off the LSJ belt. Does the tensioner bolt up, no drilling and tapping required?
Q2 - The alternator will run in reverse but it still puts out a charge just fine?
Q3 - LSJ oil dip stick required?
Q4 - Is there a bracket that goes underneath the LSJ intake manifold/intercooler or does it just bolt to the engine?
Old 10-30-2014, 06:45 PM
sandman's Avatar
1) yes. it bolts up but you might have to grind a little bit where your old engine hoist point bolted into. No biggie.
3) No. you can use stock one and bend to your wishes.
4) There is a bracket and it is part of or attaches to the HE pump bracket
Old 11-13-2014, 01:00 AM
cobalt_sport08's Avatar
i had issues finding a belt size and its still loose actually until i can pulley down and run the stage 2 belt.
how is yours?
Old 11-13-2014, 08:21 AM
sandman's Avatar
I'm running a 3.1 with a stage 2 belt. Do you have a stock pulley with the stock belt?
Old 11-13-2014, 01:40 PM
yea
Old 11-13-2014, 03:29 PM
sandman's Avatar
something must be wrong with the tensioner if its loose.
Old 11-13-2014, 04:18 PM
Haven't really looked at it in a while but it's also probably why when I punch it in 2 doing 35-40 my rpms go up then back down.. Belt slip -__-
Old 11-13-2014, 06:17 PM
sandman's Avatar
so when you floor it in second at say 35 ish and you keep it floored your rpms go up and then back down?
or is it boost going up and back down?
Old 11-13-2014, 11:17 PM
yeah rpms sorry i mean hell could be both i cant really look at both at the same time :/
but i just got a screen recoder for my tablet so im going to record the data from my torque app and look at the rpm and boost.
Old 11-14-2014, 12:05 AM
sandman's Avatar
take a vid lol
Old 11-17-2014, 08:09 PM
Verbatim's Avatar
Originally Posted by cobalt_sport08
yea
you need stage 2 belt junior
beck, me, hunterkillr, bunch of others...rock the lsj idler and tensioner with 1 rib cut
you must use the stage 2 belt
you need to grind a bit of the head to make tensioner fit, but no biggie at all
My le5 alternator has been fine, been boosted for over 40K miles, and I daily it
no, but if you can get one cheap enough, it just looks nicer...i still havent gotten around to putting a lsj one in mine
there is a bracket, 2 bolts that bolt to block then 1 bolt that goes to intake manifold(behind alternator-ish. is also part of the heat exchanger bracket
look at becks build, and hunterkillrs build
05-28-2022 03:47 AM
brandon04
10-21-2015 07:04 AM
ThoR294
10-04-2015 08:44 PM
ThoR294
09-28-2015 05:31 PM
z28addiction
09-28-2015 12:03 AM
Quick Reply: Supercharger swap Qs
