swapping 4t45e tranny with 4t65 tranny
Plus the Cobalt's Transmission Control Module will not easily be adapt to the 65E even WITH HPT support. This is because the up/downshift solenoid logic is totally different (4T65E= 11, 01, 00, 10 and the 4T45E is 10, 00,01,11) and the Line pressure control solenoid uses a totally different base frequency.
Looking closer, the solenoid logic is only different for the one solenoid and it is opposite in every gear. Just run the 45e signal through a standard relay before it hits the trans and that issue is solved.
I found a cheap pwm frequency converter too ...
Well **** ... I'm getting close to answering my own question. I'm finding that some sources list the valves as the same exact part whereas others do not. In addition pictures of both make them look very, very similar. This is hinting that the valves don't in fact matter. I'm still wanting to hear from those more in the know though.
4T40E, 4T45E Transmission Parts GM Transmission Parts FWD
This site lists the valves as being the same part between 45 and 65. (As well as many other GM transmissions.)
Judging by what I've learned so far about PWM, the frequency doesn't really matter to the valve, its the duty cycle that matters which is determined by the ECM. I'm betting my 45 TCM can control the 65 just fine with the addition of a standard 5-pin relay to invert the solenoid B signal.
I'm beginning to think that no one has actually done this and the internet is just full of bs'ers who want to make the claim but haven't actually done it. I've reached out to 5 people who claim to have done it and none of them have replied back ...
ThoR294
10-04-2015 08:44 PM
