Timken Wheel Bearing Part Number
Old Jul 26, 2013 | 10:59 PM
Joe22's Avatar
Hey guys was looking at replacing my front wheel bearing because it's making noise but not sure which wheel bearing to get. When it asks Sport or Non Sport suspension is it refering to FE5 as sport or just the FE3 or how would I tell? Thanks!
HA590068 - Non Sport Suspension
HA590086 - Sport Suspension
Old Jul 26, 2013 | 11:06 PM
LS6Rally's Avatar
086 - sport suspension
If your looking at rock auto, click the blue info button.
The 068 has a 3.97 bolt circle - 4x100
The 086 has a 4.33 bolt circle - 5x110
Old Jul 26, 2013 | 11:08 PM
Spawne32's Avatar
yeh i gotta do wheel bearings on my car too, HA590086 sport suspension, 118 bucks each
Old Jul 27, 2013 | 12:21 AM
Joe22's Avatar
Ahhhh the 068 is 4 lug. Couldn't see, should of pressed the next image button lol.. Thanks guys.
Old Jul 29, 2013 | 11:34 PM
Joe22's Avatar
So it's louder when I take a sharp left turn and quieter when I take a sharp right turn. So that means it's my right wheel bearing, right? Should I just do both of them? You guys usually just do the 1 or both at same time, the other one will probably go out next anyways right?
Old Jul 29, 2013 | 11:49 PM
Spawne32's Avatar
If you cant pin it down to which one it is, just do both. Sometimes when they get really bad the wheel will wobble when you spin it, other times you can spin the wheel and it will sound like the wheel bearing is full of sand, and makes a distinct sound like sandpaper rubbing together as you spin the wheel. Ive had some cars where if you twist the wheel left and right with your hands while its jacked up the wheel will feel loose, other times that can be a symptom of a bad tie rod.
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
metroplex
Sep 27, 2015 07:48 AM
