Timken Wheel Bearing Part Number
Hey guys was looking at replacing my front wheel bearing because it's making noise but not sure which wheel bearing to get. When it asks Sport or Non Sport suspension is it refering to FE5 as sport or just the FE3 or how would I tell? Thanks!
HA590068 - Non Sport Suspension
HA590086 - Sport Suspension
So it's louder when I take a sharp left turn and quieter when I take a sharp right turn. So that means it's my right wheel bearing, right? Should I just do both of them? You guys usually just do the 1 or both at same time, the other one will probably go out next anyways right?
If you cant pin it down to which one it is, just do both. Sometimes when they get really bad the wheel will wobble when you spin it, other times you can spin the wheel and it will sound like the wheel bearing is full of sand, and makes a distinct sound like sandpaper rubbing together as you spin the wheel. Ive had some cars where if you twist the wheel left and right with your hands while its jacked up the wheel will feel loose, other times that can be a symptom of a bad tie rod.
lol.. Thanks guys.
