turbo on the 2.4 ss 5spd
Old Mar 18, 2011 | 02:38 PM
cweb_09's Avatar
I have an 07 cobalt ss 2.4 5spd i took it to a mechanic to get a turbo installed the kit i bought did not include a turbo manifold and i am having a really hard time finding one i need help please!!!! Also will it be safe to run on 4si boost with stock internals.. and what else will i need other than kit, injectors, fuel pump t3 turbo manifold. I would appreciate any help im stuck untill i can get this manifold and more info.. Thanks
Old Mar 18, 2011 | 03:51 PM
NJHK's Avatar
I sent you a PM.
Old Mar 18, 2011 | 03:52 PM
heathkidder's Avatar
u can run up to like 10 psi i believe safely
Old Mar 18, 2011 | 05:05 PM
DFZ24's Avatar
where you got the turbo kit from?
im running 10-11psi on stock, the car has gone to 13.6psi (by interceptor) without issues.
Old Mar 18, 2011 | 05:08 PM
riko540's Avatar
yes 4 psi is fine for stock internals
Old Mar 18, 2011 | 05:35 PM
elecblue06's Avatar
what kit did you buy.. what flange is the turbo... i'm running 8 psi on the ss/tc turbo now.. i was runnign 13 psi on my procharger before.. long as it's pre 08 the 2.4s can take a beating .. post 08 it's hit or miss if you have forged rods
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
