Uh oh... It's coming...
Old Oct 21, 2009 | 01:30 PM
  #51
Illini_06SS's Avatar
Originally Posted by BradSi
s/c looks right at home. look forward to #'s.
#'s will be a long ways off. The closest dyno to me is a 2.5 hour drive. Not looking for a dyno queen, I'm planning on AutoXing this baby.
Old Oct 21, 2009 | 01:33 PM
  #52
BradSi's Avatar
autox > track
Knew you were gonna autox it. Just wondering what this setup would rate.
Old Oct 21, 2009 | 01:36 PM
  #53
kburgess04's Avatar
do you have any suspension work done?
Old Oct 21, 2009 | 01:56 PM
  #54
Not yet, but this winter I plan on doing the SS/TC FE5 swap with shocks, struts, springs, and sway bar. We'll see how that works and if I feel like I need a rear sway bar added to the mix.
autox > track
I have no clue. Glen229 had a similar setup before and hit mid-high 250s whp with a manual transmission.
Last edited by Illini_06SS; Oct 21, 2009 at 01:56 PM. Reason: Automerged Doublepost
Old Oct 27, 2009 | 08:21 PM
  #55
Finally got around to uploading some videos and taking one of when the car was running right (sort of).
First one here is the first start up since putting on the M62. The high idle and big rev at the end is because the LS4 throttle body was sticking a little. Loosening the 4 TB bolts and repositioning the LS4 solved that problem. It also had a bad vacuum leak that made it shutter and idle like absolute crap
This second one was taken this evening. I torqued down all of my bolts again and the vacuum leak seems to have been fixed by that. Now I'm just running ridiculously rich and that (and the LS4 not being dialed in) is what is causing my unsteady idle. Pegging the wideband at 10.0 while at idle isn't the best thing, no? You can see that it dumped too much fuel into it when I goosed the throttle and I actually flooded the engine!
And here's one showing the very quick spike of boost that I get when juicing the throttle (before the Auto tranny nanny-mode kicks in at 4k rpms and closes the throttle body to prevent it from over-revving the torque converter).
Old Nov 9, 2009 | 11:12 PM
  #56
It's running! Still have some work to do on the tune, but god DAMN does it pull hard now! I'm lovin' it. It's going to be hard to keep my foot out of it
The LS4 was incredibly easy to tune with! I think I'm the first LE5 to go for it and I love the throttle response. For future reference, an idle scalar of 4500 is what made my idle as smooth as butter with the LS4 TB.
Old Nov 10, 2009 | 09:30 PM
  #57
Muahaha, I'm having waaaaay too much fun with this car now! Here are some quick vids of the car doing some pulls. got some work to do still, obviously...
Old Nov 10, 2009 | 09:40 PM
  #58
whyyoumadson?'s Avatar
your running 14.8-15.0 AFR at WOT. way too lean for boost. be careful
Old Nov 10, 2009 | 09:56 PM
  #59
Yeah I'm not staying into it long (a few seconds on each pull) and I don't plan on doing any more WOT pulls (wanted to get some vids to put up at the very least), but that's the part where I said that we have some work to do still...
Old Nov 10, 2009 | 11:51 PM
  #60
HunterKiller89's Avatar
do NOT even do short pulls like that. thats begging for a blown piston.
Old Nov 11, 2009 | 02:07 AM
  #61
sundevil07's Avatar
Now, me and the mad scientist got to rip apart the block... and replace the piston rings you fried.
Old Nov 11, 2009 | 09:08 AM
  #62
pjk91's Avatar
fried the piston ring, already?
Old Nov 11, 2009 | 09:23 AM
  #63
1BADSS/SC's Avatar
good to see it running
bad it isnt tuned right yet. GET IT TUNED CORRECTLY!
Old Nov 11, 2009 | 09:27 AM
  #64
Roger. Didn't think quick pulls were enough to **** stuff up, but I'll be sure to stay gentle on it from here on out.
Not that I'm aware of :P
Yeah, I'm hoping the tuning crap gets solved soon...
Old Nov 11, 2009 | 09:28 AM
  #65
1BADSS/SC's Avatar
you want to have AFR of 11-12 to be safe. Im more conservative and think its better to run rich than lean.
Old Nov 11, 2009 | 01:28 PM
  #66
stenguyen1's Avatar
^^^ yea your right. you don't wanna push it when its lean. but once you get ur fuel all set in. you will be doing non stop pulls.
Old Nov 19, 2009 | 10:51 PM
  #67
Woohoo! Got the tune buttoned up this afternoon! The thing is fun as hell to drive and it's got some serious kick to it (and tons of torque steer FTL)!
Word to the wise, the reason I was still hitting high 14's on my AFR on those vids was because we forgot to disable the P0108 DTC which pretty much makes the computer go all Emo, hate life, and refuse to go into PE. Again, if you're going to use your stock MAP sensor, DISABLE DTC P0108!!! Also, why the F#CK are there 4 DIFFERENT DTC's FOR REMOVING THE SECOND O2 SENSOR?!?!?! Thank god I noticed the CEL flash up with the inactivity CEL before my tuner left... If anyone needs all 4 of those specific codes, I can get them for ya.
OK, time to go have some fun with the car now!
Oh, and an idle scalar of 4500 made my LS4 throttle body run SMOOTH AS BUTTER on my build! Am I the first one to try to put an LS4 TB on an M62'd LE5?
Old Nov 19, 2009 | 10:53 PM
  #68
sundevil07's Avatar
very nice! waiting for vids!!
Old Nov 19, 2009 | 11:00 PM
  #69
scottyguy401's Avatar
I tried back when I did my install in april. But I couldn't get it to fit since the adapter plate made it stick out too much. I could of probably got it to fit without the adapter, but I'm fine with my ported lsj I guess.
  #70
This thing is a constant project. I'm probably going to have to rerun my IC cooling lines. I was under the car last night and noticed that the outlet tube from the IC pump was completely bent over on itself...
Old Nov 25, 2009 | 11:28 AM
  #71
Had another CEL. Checked it out yesterday. Rear O2 sensor DTC #5... P2A01...
Ended up doing some searching and there is a total of 8 DTC's that cover the rear O2 sensor... I'm going to be disabling ALL of them now.
Old Nov 25, 2009 | 11:45 AM
  #72
1BADSS/SC's Avatar
yikes man...
Did u get it tuned yet??
Old Nov 25, 2009 | 12:37 PM
  #73
yikes man...
Yeah it's tuned now. Holding ~11.6 at WOT (and sucks gas like no other ) Just didn't get all the O2 codes taken care of. I may be able to get it taken care of today.
Old Dec 4, 2009 | 11:30 AM
  #74
Quick update:
I took the day off of work yesterday to relax a bit. Things have been hectic recently so I needed some time to just chill. I decided to replace all the ugly ass white/clear zip ties that I had used with black ones. It looks so much better now and it's not nearly as glaringly obvious that what's under the hood isn't completely stock.
One thing I did notice that was alarming was that my upper radiator hose was rubbing against the edge of the sheetmetal of my front clip/radiator support. It had worn through the braiding and was just starting to lightly mar the surface of the tube itself (thankfully there was no structural damage to the tube). It looks like this is another problem caused by the automatic Cobalts' engines being rotated forward slightly. My fix was to take ~6" of 1/2" ID hose, cut it open, and use it to cover the sharp edge of the sheet metal to prevent it from cutting into the radiator hose any further. The radiator hose itself provides enough pressure against the tube to keep it in place.
Anyone who is a supercharged Auto PLEASE take a look at this area closely to ensure that you aren't going to spring a coolant leak and if your upper radiator hose is damaged, replace it now.
Old Dec 5, 2009 | 12:45 AM
  #75
Dragonsfire12345's Avatar
I'll have to check that in the morning
