Vibrant Downpipe
Old Aug 19, 2009 | 11:43 AM
Ducky22287's Avatar
Vibrant Downpipe
Ok, so I have the vibrant header-d/p combo in my car and it seems that the flex area part of the downpipe is laying on the (I'm assuming) sway bar. Does anyone else have this problem and is there a fix for it?
Old Aug 19, 2009 | 11:46 AM
JimHarr18's Avatar
which model cobalt do you have? i have the same combo as you and i have no issues.
Old Aug 19, 2009 | 11:47 AM
Ducky22287's Avatar
2007 2.4l
Old Aug 20, 2009 | 03:59 AM
cwlaser90's Avatar
mines a 06 2.4 with the same setup. mine had no issues like that either but i also cant remember if my sway bar was in that exact spot tho. i dont think it was.
Old Aug 20, 2009 | 09:43 AM
Dunkinuts's Avatar
my 08 has had any issues with that. my thought is something isn't fully tight.
Old Aug 20, 2009 | 11:24 PM
Ducky22287's Avatar
Hmm, I checked and everything seemed tight, I'll probably do a second round just to double check. What do you guys think a good solution would be? I was thinking fiber glass wrap around the sway bar..
Old Aug 21, 2009 | 01:13 AM
Dave7417's Avatar
If I'm not mistaken, you have an automatic. If so, could it be the same problem with different length downpipes experienced when attempting to fit the LSJ downpipe?
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4-auto-exhaust-questions-178266/
and
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4l-auto-dp-vs-lsj-dp-150651/
Old Aug 21, 2009 | 11:54 AM
Ducky22287's Avatar
Oh wow, there your right, except they had problems with the cat, not the flex pipe but probably the same problem. Aside from dicing up the d/p is there a better way to get it not to rattle? (Kinda like my wrap idea).
Old Aug 21, 2009 | 11:19 PM
Ducky22287's Avatar
Old Aug 23, 2009 | 12:20 AM
Dave7417's Avatar
I have never looked closely at the FE3 sway bar setup, but is it possible that you could rotate and reposition the sway bar? The FE5 endlinks are shorter than the FE3 (I believe). Would changing endlinks swing the sway bar out of the way a little? (I'm just guessing here.)
Old Aug 25, 2009 | 12:32 PM
Ducky22287's Avatar
I took a look under the car at the sway bar and I don't even know if I could rotate it lol. Its got twist and turns all over it haha.
Old Aug 25, 2009 | 01:07 PM
JapEatr's Avatar
South Central *********
mill a couple of spacers for the auto transmission mount in the rear. This will rotate the egine forward.
See Rotated Trans Mounts for reference
Old Aug 27, 2009 | 01:30 AM
Ducky22287's Avatar
I don't quite follow, could you explain some more?
Old Aug 27, 2009 | 01:35 AM
MikeyB's Avatar
Your first problem is you have an automatic
my vibrant set up wasn't even close like yours
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 27, 2015 11:10 PM
