Who's the fastest 2.4 on here right now?
Old Nov 23, 2008 | 04:58 PM
  #51
slowswap's Avatar
Originally Posted by Dunkinuts
yeah and people said 14s on a stock 2.4L was impossible too. I am not saying I will hit 14 flat but I really don't think that a full bolt on 2.4L with the RKsport hood will be slower then 14.4 at best. I mean with good tires I could hit in the 14.6-14.7 range. So you don't think full exhaust, tune, "ram" air and better tires will net me a half a second?!?!?! Your crazy.
The problem is, the more performance mods you get, aka exhaust and header move your powerband to the upper RPM's. This will in turn make it much harder to pull through the first couple of gears. RedSSNA chose some mods to help improve his chances of keeping the torque down low but it still doesn't start to pull hard till 3rd gear. Gain something somewhere and you have to give it up somewhere else.
Old Nov 23, 2008 | 06:39 PM
  #52
Dunkinuts's Avatar
agreed, I understand 13s is a stretch but low 14s isn't. I think that the mods will give me at least .4 in the 1/4 tires alone should be a tenth or two.
Old Nov 23, 2008 | 06:40 PM
  #53
Jimmys2007CobaltSS/C's Avatar
never dynod or took my to the track but she was fast
Old Nov 24, 2008 | 01:08 AM
  #54
mmcgee123's Avatar
i ran a 15.04 at 94 B4 i got the nitrous so weil findout this friday
Old Nov 24, 2008 | 02:06 AM
  #55
ssbalt06's Avatar
Originally Posted by pjk91
these threads are rediculous.
haha agreed .... for me guys- low and slow
Old Nov 24, 2008 | 09:25 AM
  #56
Dunkinuts's Avatar
best of luck, I am interested to see what a 75 does for a bolt on 2.4
Old Nov 24, 2008 | 12:08 PM
  #57
IonNinja's Avatar
Originally Posted by xCobalt05x
ok, how about the SAE correction chart? SAE is the most aggresive correction for a dyno and with SAE i still dyno'd at 242whp? would you like to see that chart too
since you're into math...check out a compressor map between the two turbos and it'll make more sense.
Old Nov 24, 2008 | 01:58 PM
  #58
celicacobalt's Avatar
Originally Posted by ralliartist
2.4 SS AND SPORT MODDED WITH POWER ADDERS
1.)celicacobalt,13.70@104.60 w/2.14 60',coupe,auto,TK/E/T/ST
2.)EcoBoost,13.78@101.74 w/2.09 60',coupe,auto,TK/E/T/ST
looks to me like celiecacobalt is the fastest, slightly ahead of ecoboost.
if you guys have slips, vids/pics, pm them too me so I can update the top 10 list.
thats an old time for me
also with all the hp and tq talk, it doesnt mean much, track times dont lie where as a dyno can alter numbers in all kinds of ways. I have seen people on here making more hp than me with slower times. track times are the best way to tell whos fastest, dynos really dont mean much.
Old Nov 24, 2008 | 02:24 PM
  #59
slowswap's Avatar
Quarter mile doesn't always mean anything because of driver mod....Roll racing is a true test of what car is faster then the other.
Old Nov 24, 2008 | 03:45 PM
  #60
Dunkinuts's Avatar
ok, so a 10 mustang vs a 10 supra from a 60 roll is really going to tell you which car is the fastest the 1/4 is the standard for a reason.
Old Nov 24, 2008 | 05:59 PM
  #61
Fire_Starter's Avatar
Lol@street racing comment. What a joke.
Old Nov 24, 2008 | 06:28 PM
  #62
sport08's Avatar
yeh street racing ftl
Old Nov 25, 2008 | 12:55 AM
  #63
2006RedCobaltSS's Avatar
I thought that Cobeezy or whatever his name was had a completely built 2.4?
Old Nov 25, 2008 | 01:40 AM
  #64
Like I said give me a few months, and its gg
Old Nov 25, 2008 | 10:40 AM
  #65
Dunkinuts's Avatar
he has never run it.
Are you only on doing it spray or are you boosting?
Old Nov 25, 2008 | 11:17 AM
  #66
Dj_BuCa's Avatar
Elevation and temperature changes everything. This thread means nothing unless all your times are at the same track, on the same day.
Old Nov 25, 2008 | 12:24 PM
  #67
Red07SSNA's Avatar
....and at the same general time...night and day temperature changes have an affect too!
Old Nov 25, 2008 | 12:36 PM
  #68
Dunkinuts's Avatar
drag times has a weather feature on it.
Old Nov 25, 2008 | 03:52 PM
  #69
Psshhh boost and built as well, maybe spray later if I really need it.
Old Nov 25, 2008 | 04:49 PM
  #70
MLRTYME's Avatar
I beg to differ...
Quarter mile is the BEST way to compare. I'll supply three reasons...and let the rest of the group agree or disagree
1- Suspension is part of the car. I have spent a lot of time, energy, tunsten and cro-moly, and harddrive space working on designs to improve the travel path of the differential and pinion angle on my Chevelle. Does this mean that my car is still only as good as a stock Chevelle? No...it is superior to a stock Chevelle suspension set up.
2- I don't care how good your car is...if the driver isn't good, then the race is lost. I've won and lost races to other dragsters and door cars of all different types. The bottom line is that the driver needs to do their part...or all the the money and upgrades in the world are worthless.
3- If you don't set a limit on exactly what the race is, then any results are completely skewed. The dragstrip is a set length, and requires a fair start; anything else is subject to interpretation ("You left too early", "the lane I'm in had potholes", "I shut down early cause I knew you couldn't beat me"...or enter in any other lame excuse a street racer has given).
The guy provides this as a measuring stick because there is NO way to cheat it! As any true racer knows...the timeslip doesn't lie...
Did I miss anything, guys???
MLRTYME
'08 Sport Coupe
www.wannaberacing.com
The NHRA uses track elevation to modify the index for Comp Eliminator, so you could most likely use a similar function to compare basic run statistics. However, most weekend warriors don't carry a full weather station and temp gun to measure track surface, barometric pressure, temp, wind, etc...
There are any number of possible issues that a racer can face. However, the bottom line is that if a racer has a timeslip that says how fast their car can run, I can't argue that. Again, the timeslip doesn't lie!
(No disrespect intended to those that have to run at Bandimere!!!! That place is MURDER on N/A cars!)
MLRTYME
'08 Sport Coupe
Old Nov 25, 2008 | 07:46 PM
  #71
Banidmere owns us
Old Dec 4, 2008 | 11:08 PM
  #72
Turbo06Sedan's Avatar
Last run was a 13.33 @ 108. I'll be faster by the end of winter for sure.
Old Dec 5, 2008 | 12:14 AM
  #73
cool, update ur sig.
red9
Oct 4, 2017 02:23 AM
Barkleyj605
Oct 24, 2015 12:07 AM
patooyee
Oct 15, 2015 05:11 PM
Hugger1975
Oct 15, 2015 03:28 PM
