zzp block
zzp block
to all the ppl who have the zzp block when you sent your core in did you send the block with everything on it except the cylinder head or what does the new block come with
the waterpump and cross over pipe on it or no i just need to figure this all out as my core is fucked so im buying a junk yard motor thru work and im goin to use the crank and balance shafts out of it
^^ correct just got done talking to matt and yes i went thru 2 blocks i was over 400whp for a long time
lots of highway pulls beat the hell out of it lol but this build should be pretty beastly when im done
If I remember correctly your dyno numbers are actually significantly lower than what you are actually making? Something to do with comparisons of an evo on buschar's dyno vs. the dyno you were on?
My best friends 04 Sti built motor gtx3582 2k injectors all supporting mods on 25psi I pulled pretty hard from a 40 roll when I was on 15 psi so I'd say 430 ish whp on my car
