zzp block
Old Oct 15, 2012 | 11:07 AM
mmcgee123's Avatar
zzp block
to all the ppl who have the zzp block when you sent your core in did you send the block with everything on it except the cylinder head or what does the new block come with
the waterpump and cross over pipe on it or no i just need to figure this all out as my core is fucked so im buying a junk yard motor thru work and im goin to use the crank and balance shafts out of it
Old Oct 15, 2012 | 01:40 PM
NICOMAN's Avatar
how long were u running 14 psi for on a stock block?(going off ur signature) and what went ?
Old Oct 15, 2012 | 02:00 PM
bluebalt07's Avatar
His sleeves went twice. And from what I remember reading before, the block doesn't come with anything. It's just the bare upper and lower portion
Old Oct 15, 2012 | 03:19 PM
mmcgee123's Avatar
^^ correct just got done talking to matt and yes i went thru 2 blocks i was over 400whp for a long time
lots of highway pulls beat the hell out of it lol but this build should be pretty beastly when im done
Old Oct 15, 2012 | 03:43 PM
bluebalt07's Avatar
If I remember correctly your dyno numbers are actually significantly lower than what you are actually making? Something to do with comparisons of an evo on buschar's dyno vs. the dyno you were on?
Old Oct 15, 2012 | 05:43 PM
mmcgee123's Avatar
Correct ^^
Old Oct 15, 2012 | 05:49 PM
OttawaMark's Avatar
check my gallery lol, doesn't even come with the timing sprockets.
Old Oct 15, 2012 | 07:22 PM
bluebalt07's Avatar
So any idea what kinda power you actually are making?
Old Oct 15, 2012 | 09:05 PM
mmcgee123's Avatar
My best friends 04 Sti built motor gtx3582 2k injectors all supporting mods on 25psi I pulled pretty hard from a 40 roll when I was on 15 psi so I'd say 430 ish whp on my car
Old Oct 15, 2012 | 10:21 PM
bluebalt07's Avatar
Sounds pretty sweet. I wanna see vids after the zzp block gets put in and boost gets turned up
Old Oct 16, 2012 | 08:30 AM
mmcgee123's Avatar
Will do
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
