2 pcm's
Old Apr 22, 2008 | 06:41 AM
matchhead's Avatar
2 pcm's
So im here in iraq and i have lots of time on my hands, and i was thinking...
i know this has been brought up before, but not much, if anything came out of it that i could find. Running 2 pcm's in the same car (07 SS S/C), not at the same time, obviously. If you had a Y connector of some sort so that you can plug them both in and then switch between the two with a switch. The only problem i see right now, other than finding/fabricating the Y connector is how to switch between the 2 pcm's. I looked at the pin out that was linked in another thread, but there isn't a power wire or anything like that, at least not that i saw. So my question is, how could it be done? Any help would be appreciated.
Old Apr 22, 2008 | 07:09 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Not worth it. Just keep the 2nd PCM in the Glovebox and switch them out when needed.
Old Apr 22, 2008 | 12:02 PM
matchhead's Avatar
Not what i was hoping for, but that was what i was expecting. Thanks
Old Apr 22, 2008 | 12:03 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Youd have to shut the car off anyways. Could you imagine if you accidentally switched PCMs mid-drive?
Old Apr 22, 2008 | 12:17 PM
LopsidedJester's Avatar
anyways, switching out PCM's only takes like a minute, disconnecting your battery before doing it would take longer than just swapping them.
Old Apr 22, 2008 | 01:08 PM
transam1998's Avatar
You could mount them both, splice the wires, then run a seperate switch for each wire into the car, your interior would look like Knight Rider.
It would take you 2 minutes of flipping switches to change over,
TedSS
101
Apr 25, 2016 10:46 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
n20saturn
Sep 21, 2015 01:50 AM
DevZX
Sep 16, 2015 06:19 PM
BettyBlue2.2
Sep 10, 2015 08:49 PM
