2nd heat coolant resevoir help pls
Old Aug 29, 2007 | 04:53 PM
-Jayson-'s Avatar
i have my bottle mounted i just cant decide how to run the coolant lines to the lower intake manifold without hitting the serpentine belt. Any pictures of advice would be appreciated.
Old Aug 29, 2007 | 10:10 PM
shiftingloco310's Avatar
when i ran mine i ran zip tied it to the wire loom going across the radiator support. then i ran through the upper radiator hose, took some long zip ties and zip tied the hose using that hole on the radiator support.
Old Aug 30, 2007 | 12:59 AM
-Jayson-'s Avatar
that works but im looking for a way that hides the hoses better, i dont want to see 2 more giant black hoses running infront of the car.
Old Aug 30, 2007 | 11:04 PM
what you can do is do like the gm time attack car did. drill a hole in the radiator support by the pass headlight and run the hose inside the radiator support ...it should come out through the hole in the center on the radiator support.
Old Aug 31, 2007 | 11:08 PM
jgarciarivera's Avatar
Check this
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/dual-pass-intercooler-68262/
Fearedbynone
Apr 14, 2016 03:25 AM
brandon04
Oct 21, 2015 07:04 AM
riceburner
Oct 2, 2015 05:47 PM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
