2nd heat coolant resevoir help pls
i have my bottle mounted i just cant decide how to run the coolant lines to the lower intake manifold without hitting the serpentine belt. Any pictures of advice would be appreciated.
when i ran mine i ran zip tied it to the wire loom going across the radiator support. then i ran through the upper radiator hose, took some long zip ties and zip tied the hose using that hole on the radiator support.
what you can do is do like the gm time attack car did. drill a hole in the radiator support by the pass headlight and run the hose inside the radiator support ...it should come out through the hole in the center on the radiator support.
