Been layin low for a while
Old May 11, 2011 | 09:01 PM
EXsoccer1921's Avatar
Talking Been layin low for a while
Well 3 years, 3 cars, and 3 different setups later. i've finally stepped up my game and dropped some real money. As some of you may know, my rpf1stuturbalt blew up on march 27th and has been sitting ever since. At first i was just wanting to drop in a crate engine. then it turned to a crate engine plus a new zzp turbo manifold but then would have to change the piping so i'd get the intercooler kit. well that changed to the zzp turbo kit+intercooler kit. and you know how things take off.... well. its time to make some real power.
ZZP 2.0L turbo LSJ block
ZZP reinforced lower girdle
Balance shaft delete
Electric water pump setup
Walbro fuel pump
Fuel pump rewire
Custom boost reference setup
Chromoly rings
ATI SFI turbo blancer
ARP flex plate bolts
Fidanza aluminum flywheel
ZZP stage 4 clutch, sachs pressure plate with full ceramic friction disk
Tapped oil pan for oil feed return
ZZP 4340 rods
JE 9.5:1 pistons
Comp Cams stage 2 turbo grind cams
ZZP 78# valvesprings +retainers
Siemens 80# injectors
Ecotec adjustable cam gears
ARP head studs
Borg Warner Billet Wheel s262 .70 a/r turbine
ZZP 316 stainless turbo manifold
ZZP 3” v-band 304 stainless downpipe with no cat, vband exit
3" mandrel bent exhaust. no resonator, no muffler
ZZP Turbo oil system kit
ZZP 3.5” aluminum turbo intake
K&N air filter
Precision 46mm wastegate
ZZP intercooler piping
ZZP 50mm blow off valve
ZZP race intercooler 28x11.5x4.5
Saab aluminum intake manifold
Throttle body and wiring adapter
Alternator for turbo setup( this and the belt tensioner will be the only things on the belt)
91 octane low boost tune
112 octane high boost tune
-Already on the car
-old 3076 dual bb oil/water cooled turbo setup(already have a buyer)
-RPF1balt Ksport coilovers
-Front slotted rotors
-hawk pads
-Poly insert trans mounts
-DSS level 2 axles
-GMPP clutch, obviously being replaced
-full 3" exhaust with muffler delete
-N2MB WOT box, 2step/nls. will only be used after i get the trans work done
-AEM AFR
-Autometer 45psi sport comp
-Dual Aeroforce gauges
-ZZP triple gauge pod
car will be picked up in a few days and then done within 2 weeks. Please do not pm me or ZZP about the electric water pump with no blance shafts as there is no kit available to the public yet because lets face it cobalt owners are cheap. this is not an engine just put together from clicks off a website either. Me and Ryan have been talking about getting a monster cobalt to run 10 flats on the track and still be drivin on the street. I think thats why things have progressed where they are because i'm not a cheap bastard, don't ask how much this is all costing, and i realize that there are many sacrifices that people fail to consider when wanting to make power that need to be taken in to account when trying to daily drive a 700+whp fwd clutch car. like pedal pressure, no hvac, vibrations from no balance shafts/mounts/etc. i can see past all that in order to make stellar times at the track. shooting for 10s on a slick and 91 tune. high 9s on the high boost and race gas once i get the transmission and ported head. have about 1000 passes under my belt on many different cars so i know i've got it in me. ps the 10.7 was done on ~550whp and a 1.8 60'
thanks again to ZZP and Ryan especially for putting up with me for over a month updates will be here as soon as they pick up the car.
leavin ft knox
at ZZP the next afternoon
new cam gears
Sport Comp series 45psi gauge from autometer
old setup
Old May 11, 2011 | 09:05 PM
TommyP's Avatar
AWD > FWD
This, is gonna be epic. Way to go big! Can't wait to see the results.
Old May 11, 2011 | 09:06 PM
DBlock's Avatar
QUEEF-NUGGETS
dont blow it up again lol
Old May 11, 2011 | 09:08 PM
lol i don't think it can blow up...
hey somebodys gotta do it
Last edited by EXsoccer1921; May 11, 2011 at 09:08 PM. Reason: Automerged Doublepost
madmark's Avatar
my car wont have a buddy to talk to him at night......but i hope you get it back before i leave! i wanna ride in a real car
Old May 11, 2011 | 09:10 PM
DBlock's Avatar
QUEEF-NUGGETS
beat james
Old May 11, 2011 | 09:13 PM
lol he won't even be able to hang with the 91 tune.
what you doin right now? wanna check out the old setup?
Last edited by EXsoccer1921; May 11, 2011 at 09:13 PM. Reason: Automerged Doublepost
Old May 11, 2011 | 09:14 PM
DBlock's Avatar
QUEEF-NUGGETS
[QUOTE=EXsoccer1921;5774327]lol he won't even be able to hang with the 91 tune.
lol i want to see,not saying you wont beat him just want to see it lol
Old May 11, 2011 | 09:15 PM
and besides, i already out drive him in his own car
Old May 11, 2011 | 09:16 PM
383_Stroker's Avatar
Damn... thats awesome man.. good luck!
DBlock's Avatar
QUEEF-NUGGETS
lol yeah i saw that,the day we went up there to port and polish bohagans sc
Old May 11, 2011 | 09:19 PM
ssyellow's Avatar
Goodluck man!
Old May 11, 2011 | 09:23 PM
WSFrazier's Avatar
Holy crap...
You mean a turbo swapped LSJ, that isn't a ZZP shop car, will actually take their car to track, and not just claim it's super duper fast?
I call shens.
Old May 11, 2011 | 09:28 PM
s.c's Avatar
s.c
Looks Can Be Deceiving.
Subscribed for progress and tokno when u and james are racing haha
Old May 11, 2011 | 09:30 PM
Chevycobaltss3's Avatar
Mark u have the biggest ego... Just since u think ure the ****.. I told u wut im doin a hole. I was thinking a efr or a damn gt35 series and. 100Shot or more......... And run meth. ..... And run say 40 lbs ******..... U outdrive me cuz i kept changin boost setting douch my 60s were 2.2s as u were cockbag... Lmao btw thought u were comin over.
Old May 11, 2011 | 09:31 PM
DBlock's Avatar
QUEEF-NUGGETS
and the war begins haha
Old May 11, 2011 | 09:32 PM
Btw mark i build my engines not buy the crapphead...... Oh yeah lets hope u get the power u want and dont blow it up.
Old May 11, 2011 | 09:33 PM
DBlock's Avatar
QUEEF-NUGGETS
Old May 11, 2011 | 09:34 PM
Lol u know mark and i are friends lol. So if he beats me. . Give me a week or so and ill beat him.
Old May 11, 2011 | 09:36 PM
DBlock's Avatar
QUEEF-NUGGETS
i know you ******* i was joking
Old May 11, 2011 | 09:38 PM
s.c's Avatar
s.c
As css turns
Old May 11, 2011 | 09:51 PM
elite_Cyborg's Avatar
You can blow anything up, trust me.
Old May 11, 2011 | 09:54 PM
Lol^^^^^^^^
Old May 11, 2011 | 09:58 PM
WSFrazier's Avatar
Troof, I've seen more idiots blow "built" motors up than succeed.
Apparently wrenching and tuning is hard.
Old May 11, 2011 | 09:59 PM
livingdeadpk's Avatar
sub'd for progress
