Cam Install Question
Old Apr 10, 2009 | 08:47 PM
XM15's Avatar
In checking several sources for cam install information, I noticed some differences. While the how-to on this site says to set the #1 piston to TDC, my chilton's manual says to set it to 60 degrees before TDC because if you set #1 to TDC you could damage the valves. I would appreciate the input of anyone with experience in doing cam swaps on the eco. Thanks!
Old Apr 14, 2009 | 07:10 PM
XM15's Avatar
Old May 19, 2009 | 09:12 PM
StevesBlack06's Avatar
TDC on #1 compression stroke, cams need to be neutral and tha should yield all valves closed.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
