DevilsOwn 2.5 gallon sumped tank
Old Jan 20, 2010 | 11:12 AM
devilsown's Avatar
http://www.alcohol-injection.com/2-5...-tank-346.html
Our 2.5 Gallon tank from DevilsOwn is the first water-methanol tank with a built in sump and fluid control baffle. This eliminates the pickup being uncovered during sprinted driving. Because of the tanks quality design and it featuring a real sump in it. You can run the tank down to approximately 1 qt of fluid before uncovering the pickup. Made with 1/4" thick HDPE which is same material and construction that is commonly used in manufacturing fuel cells.
Dimensions are 8" x 13.5" x 8.5". So It's best suited for trunk placement.
This tank features a 2 1/4" opening for easy fill up. This tank can be used for any alcohol water mixtures. It's 100% methanol compatible. Tanks design also allows for proper ventilation for the pump heat. Vented cap is included. This tank does not come with drain fitting. We recommend our self sealing bulkhead.
  • Features a real sump
  • Internal baffle for fluid control under braking
  • Same material and construction as fuel cells
  • Proper cooling for the pump.
  • Includes brackets and mounting hardware
Old Feb 22, 2010 | 02:11 PM
devilsown's Avatar
Yes there has been a ton on engineering that went into this tank. I love doing this kinda stuff. Went over quite a few designs to try and come up with the best one. I original wanted to hide the pump in tank for a clean look but heat became an issue. Pump can generated 150 degs of heat pretty quickly when enclosed with no airflow. Like a trunk install. Which is where most people will be putting them. This is why i chooses to keep the pump open so it can natural dissipate heat better.
The graph below shows the heat rise of the pumps with 70f air temps. How quick will the pumps get to 150 degs in the trunk of a car during the summer? How hot does your trunk get? Well the plastic the tanks are made out of start to soften up at 150 degs.
About cost yes these like others custom made tanks are not the cheap . It cost a fair amount of investment for mold. All the steel in it all the time it took to weld it fill it grind it. But some of the things i want to point out is the quality of construction. Our tanks are thicker construction than off the shelf 2.5 gallon tanks. There are reasons for making the tank thicker which i will get into latter.
See the weight difference same size tank.
Old Feb 22, 2010 | 02:18 PM
BeradSS's Avatar
Looks real nice....but on another note i've done a little plastic/molding myself. I hope that plastic holds up well, i had some stuff that looked just like that, it cracked really easily.
Old Feb 22, 2010 | 02:25 PM
devilsown's Avatar
These are being made by the same company that made all of hardwood fuel cells. Same machines etc. These people know there stuff.
Old Feb 23, 2010 | 04:00 PM
devilsown's Avatar
Any other questions about these tanks?
Old Mar 30, 2010 | 07:53 PM
devilsown's Avatar
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
riceburner
Sep 26, 2015 12:57 AM
