Dual Pass Opt B with Cobra Heat Exchanger Help
Ok, with chances of embarrassing myself with my awesome paintbrush skills, I am a bit confused as to where the t goes. I have read lots of threads so I am pretty sure I have the right concept, just not sure if the extra reservoir gets hot or cold coolant, you would think hot though.
Updated Picture on Post #30
Well, the Cobra H/E is separate anyway. my understanding of the option B setup is that the T goes into the stock resivior location, which would be the hot side, Diagram A that you have.
Numder 2 the 1st one is wrong!
you have 2 out ports on the endplate>>> Them get tied together with 1 T then a short piece of Hose & the other T<<< From that T 1 goes to the reservoir & the other goes to Pump in! Then Pump out goes to H/E In>>> Then H/E Out goes to endplate center Port! Dont forget to Change your laminova's, Been running it awhile Now works Great!
Where does the line all the way on the left go, from the reservoir? Also, is there a brass fitting on the stock heat exchanger?
Also, just from a thermal standpoint, I think option B would be better as you don't want hot water to sent to the surge tank. Then again I am taking a portion of this from water cooling computers.
Regards,
Ryan
Regards,
Ryan
Regards,
Ryan
Regards,
Ryan
What part is confusing to you? The plug/fitting thing? Look to the left of your hood latch on the top of the H/E. That little nut comes out and the adapter goes back in, then plugs into the lines for the bottle as shown. Not much to draw out.
Question for you Bill, and anyone else running the Option B setup - what evidence do you have that it actually does anything? I noticed a difference with the dual-pass, but the option B seems very unnecessary to me, unless you are unable to bleed the system yourself, which was not a problem for me.
This is just simple Thermal Dynamics!
Regards,
Ryan
Regards,
Ryan
You have a 1/4 line that comes off the top of the Stock H/E & goes to the 1/4 inlet on the reservoir & the 3/4 Line goes from the resevoir to the last T!
If we run the same amount & the engine is Hot >>>> You will have more Heat soak than I do simply because when fluid gets hot( ie: water antifreeze it creates more airbubbles which is why Option b has a exspansion Chamber to bleed off the air that has built up! Plus it increases fluid amouts which takes more time to heat soak! Air is the biggest killer of our systems & that Little neck has no room to let it out!
The thing is, I know the theory behind it, which is what you said, but I want to know if anyone can actually show proof/evidence/facts that Option B does anything. I know you don't drive your car as hard as I do, and the only time you should theoretically see a difference is in a road-race or endurance event where the car sees full boost all the time for extended periods, but even then the extra quart or so won't help any more than anything else, just delay the temp rise for a few more seconds if working as designed. That is the fundamental problem I have with Option B, I doubt that it does anything worthwhile for a street car. I hope someone comes in and proves me wrong, but I don't see it happening.
Once properly bled, the little neck fucntions fine, but it can take weeks of letting it drop and adding a small amount of fluid until it stabilizes.
Plan & Simple you drive in rush hour with a Moded car you should be running option B, I dont think you will find any that did a study with both & logged it on HP Tuners & GM Must Know it works they just gave you the cheap way & the right way as Options it anit that hard to understand! That little neck isn't even close to giving you enough room & when I drive my car I drive hard! Any1 running 2.9 or lower should be running this system to benefit fully! They made it to go with stage 2 & UP My car Never gets above outside air & the More fluid you run like that the Longer it gets to Cool can't see why you would question that Longer exsposed the More it cools! Plus I didn't increase a Quart I increased a Gallon & a Half Big benefit!
Last edited by ItalianJoe1; Sep 19, 2007 at 09:13 PM. Reason: Automerged Doublepost
anyone?
anyone?
after doing option B and upgrading the intercooler pump, i'm not just bleeding air, i'm getting a constant stream coming out of the 1/4" hose into my reservior. I'm not sure its good, but it means that there is some decent flow from the reservior, and with option B you can throw a bunch of ice in the reservior before going out to the track and keep temps lower longer.
anyone?
anyone?
I am not sold on either. I think there is a better way if you bleed the top witht he bleeder then the rad is good. I thinkg the tank should be inline. the tank should be used as a way to increase capacity and then system would be less prone to heat sink.
otherwise it has to be option A IMO
The Feed Lines to the H/E need to be swapped in this Pic, You want to run into the Stock H/E then to the Cobra H/E Then back out to the Center Port of the Endplate! The Pump is inline before the H/E, Then when coming out of the Last H/E it goes directly into the center Port!
Another words out of the endplate into the Pump>>> Then out of the Pump to the stock H/E>>> Then out of the Stock H/E into the Cobra H/E>>> Then out of the Cobra H/E into the Center Port of the Enplate! Other than That the Diagram is Pretty close!
