engine swap
engine swap
So my brother has a pontiac sunfire that has the exact engine as mine (2.2) My point to this thread is on the hahn racecraft if i turbo mine the most i can get out of it is 194 hp and if i turbo the sunfire it can get up to 600 hp. WHAT ON EARTH HAHN RACECRAFT!!!! anywho is it wise to put that engine in my car so i can turbo it and get more power.
LOL... GM destroked the 2.2L eco to a 2.0L and pulled 1440whp out of it.
you can pull alot more than 194hp out of that motor... your buddy isn't going to get 600whp with just a bolt on turbo kit.
hit up ZZPerformance.com
almost everything you said here was wrong, FYI
actually your buddy can get 600 whp with a turbo kit but its gonna be expensive and the motor wont last more than like 10 runs.. the connecting rods will bend at 350 and the trans will only hold 260 whp for like 30000 miles. so u can hit any number you want but, it wont last and neither will your drive train.. plus 600 hp front wheel drive is not a driveable car at all. 260 whp is a good number that will max out the reliability of the car. the more boost that is efficiently allowed into the cylinder the more power you make... so just do something realistic that he can drive and more than likely its his daily driver. that being said i would go over 260 whp with the stock l61 platform. if you want more you can build it so but with great power comes great sacrafice.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 1, 2015 01:07 PM
