first htv 1320 received
I can see a showdown already:
Lysholm 1200AX vs. HTV1320
Umm... yeah bit of an oops on my part there.... I read from the wrong row.
Our T-MAP is Bosch pn; 0 261 230 042
It is rated for 20-250 kpa absolute (.2-2.5 bar absolute), where the 2.5bar reading is a 4.65V
That means it will read up to 21.76 psi gauge, with about a 2 psi overshoot, which peaks the voltage at 5V.
The direct replacement part numbers for the higher rated T-MAP's are;
3 bar abs -> 0 281 002 437
3.5 bar abs -> 0 281 002 456
4 bar abs -> B 261 260 508
You can find all needed info on pages 34-37 on this link.
I have to find a vendor that can supply me with a 3 or 3.5 bar replacement.
just another blower!? big deal. still a heaton.
what kind of gains do you expect at the track from that in terms of times. cut the crap about efficiency, less HEAT (LOL) and stuff. really how much quicker will your car be?
I am not hatting here. we have seen so many mods from procharger to twin screw to turbo. the only thing that has shown promise is turbo and we are still waiting for times before their transmission falls out.
(FLAME SUIT IS ON)
(FLAME SUIT IS ON)
That's what I'm thinking. I haven't got to experience the HTV, but I know exactly what the twinscrew is capabale of. My 272whp Mustang dyno numbers really didn't show what the car was doing performance wise. Just food for thought.
I do however know my blower was capable of slinging oil from the snout like a champ!
(FLAME SUIT IS ON)
(FLAME SUIT IS ON)
(FLAME SUIT IS ON)
(FLAME SUIT IS ON)
Wait till we see what the dyno comes out to look like or at least logs of the airflow sensors.
If you are worried about the transmission perhaps you purchased the wrong car.
EFILive has support for tables that may or may not be ones that HPTuners supports. Modifying how P0068 tests run may be in that arsenal (or at least the calculations for building the intake manifold models for p0068). I'm still waiting for their guys to post up a stock calibration.
One good thing is, the SCIP sensor seems to still be happy on the TVS even with an increase in volume between the supercharger rotors and throttle body which will probably make wanting to change p0068 tests unecessary.
Edit:
Found it... all the T-MAP's are +/- 1.5%
Therefore the 250kpa sensor is +/- 3.75kpa, the 300kpa is +/- 4.5kpa, 350kpa is +/- 5.25kpa, etc, etc.
Correct. However the only places I would lose it that matters is the IFR and injector offset table.
carry on
bottom line - relax. I will get excited if you hit 12's and maintain reliability. I hope but I dont give much.
Worried about it? LOL bought the wrong car? LOL. Your right. and GM has replaced my transmission and are not offering stage kits for the 08 TC cause tranny is maxed for torque. Just saying it looks like to me that it is that way.
Rotors mean squat, boost map means squat, and yeah I have looked at all of that. there is no doubt that there is improvement over the original. but what will it equate to for track times. even for a dyno I know the curve will look great. but can the car hold up? read last comment for the fear.
LNF fanboy?
Click link in sig....
