first htv 1320 received
Old Mar 20, 2008 | 01:18 PM
  #551
SK360's Avatar
Originally Posted by Witt
Shoulda came out with us last night imo.
Should come out with me tonight....
IMFO
Old Mar 20, 2008 | 01:19 PM
  #552
Witt's Avatar
Originally Posted by Area47
bwhahahahahahhaha
go hurt some gto owners pride. again. this time, don't lube it. stick it in dry and fast
Nah, we just talk a bunch of **** back and forth. Its the redlines we like to **** with.
Especially turbo swapped ones.
Old Mar 20, 2008 | 01:20 PM
  #553
SK360's Avatar
I'll take that tupperware box 0-60... you handle the rest.
Old Mar 20, 2008 | 01:21 PM
  #554
Blown 4-banger's Avatar
Originally Posted by Omega_5
Was that PSIA or PSIG?
Edit:
~36psia is about 22psig
It was absolute pressure.
Old Mar 20, 2008 | 01:22 PM
  #555
Witt's Avatar
Need the damn track to open sooner. And my new Hoosiers mounted too.
Old Mar 20, 2008 | 01:26 PM
  #556
Omega_5's Avatar
... that sounds right.
The sensor should peak out around the ~50.7 psia, or 36.3 psig mark.
we've got lots of room to move with that sensor....
Old Mar 20, 2008 | 01:29 PM
  #557
Josh@ottp's Avatar
its 36 psia
Old Mar 20, 2008 | 01:32 PM
  #558
SK360's Avatar
Dunno. Maybe they illegally import fast cars.
snapz.
I don't think they need to import anything
Old Mar 20, 2008 | 01:33 PM
  #559
Witt's Avatar
If you look at this pic you can see where I ground off the two "fins" on both sides of the stock bolt hole location. I also ground off half the tab to allow the snout fin to fit. You then rotate the TMAP sensor about 20 degrees or so clockwise, then I used that notch I cut in it as a new mount for the stock bolt.
  #560
Area47's Avatar
Rent me! per hour
the tupperware drivers are sensative!
Old Mar 20, 2008 | 01:34 PM
  #561
Witt's Avatar
I see they sell Grand Prixs over there.
Looks heavy imo.
Old Mar 20, 2008 | 01:37 PM
  #562
Area47's Avatar
Rent me! per hour
[img]overkill[/img]
http://www.youtube.com/watch?v=EfMDZ4GR1Uc
shiney don't mean ****!
Old Mar 20, 2008 | 01:40 PM
  #563
SK360's Avatar
No, the REAL blower sticking out of the hood does tho.
Old Mar 20, 2008 | 01:42 PM
  #564
Witt's Avatar
ouch.
Old Mar 20, 2008 | 01:45 PM
  #565
Area47's Avatar
Rent me! per hour
blower through the hood don't mean anything
Old Mar 20, 2008 | 01:46 PM
  #566
Witt's Avatar
Some random BS pics:
New blower with the M62 bypass attached:
  #567
BRN169's Avatar
Originally Posted by Raven SS
i bet alot of people feel the same way..with the turbo'd balt coming out u dont stand out so much..a Harrop HTV1320 supercharged cobalt is where its at
Won't it be a bitch if people start to buy SS/TCs and swap the turbo for one of these HTVSs... LOL With the upgraded brakes and "no lift shift" that would be bad ass...
Old Mar 20, 2008 | 01:47 PM
  #568
Omega_5's Avatar
What, specifically, were you hitting that you had to rotate it?
Edit:
Curious for my intake design...
Old Mar 20, 2008 | 01:50 PM
  #569
Witt's Avatar
Originally Posted by BRN169
Won't it be a bitch if people start to buy SS/TCs and swap the turbo for one of these HTVSs... LOL With the upgraded brakes and "no lift *****" that would be bad ass...
A GT3076r would be easier/economical imo for them.
The position that it sits on the manifold. Stock the TMap sits with the wire harness in the 6 oclock position. You have to modify it to sit in the 7 oclock position. I'll have pics in a bit of what it looks like with the blower mounted and the TMAP modified.
Edit:
It's because the tmap in the stock position will not clear one of the snout fins and a snout bolt btw.
Old Mar 20, 2008 | 01:51 PM
  #570
Area47's Avatar
Rent me! per hour
witt. you have a golden m62. stop showering it with oil.
won't fit
Old Mar 20, 2008 | 01:52 PM
  #571
Witt's Avatar
won't fit
Ha, I've heard that one before. Refer to Dan's Holset.
BTW stock blower case has always had a gold tint to it, no idea why.
Old Mar 20, 2008 | 01:55 PM
  #572
Omega_5's Avatar
Looking at those pictures of the blowers side by side, I think I understand why.
Old Mar 20, 2008 | 01:57 PM
  #573
Witt's Avatar
If you see the difference in the way the snout fins are shaped you can see why.
Hmm, brand new rainbow six vegas 2 CE in the package or play with car? Decisions decisions.
Old Mar 20, 2008 | 02:13 PM
  #574
spike's Avatar
won't fit
hahn has a bigger gt35r..........fits fine....behind the motor............
Old Mar 20, 2008 | 02:20 PM
  #575
memphisr24's Avatar
So is it safe to say that the htvs is in between a garrett gt28 and a gt30? Or is it almost equivalent to a gt30? (power wise/cfm wise)
