first htv 1320 received
Old Mar 20, 2008 | 12:23 PM
  #501
06blackg85ss's Avatar
btw whats the max the stock MAP wil register with the comp, cause I've logged my car and it peaks at 22.34 psi (I'm hoping I'm not pushing it higher than that) also blew a coupler apart this morning... damnit
Old Mar 20, 2008 | 12:24 PM
  #502
lsjwannabe's Avatar
i believe 23 or 24 and mine hits it at 6200
Old Mar 20, 2008 | 12:27 PM
  #503
Area47's Avatar
Rent me! per hour
ya know. i saw this comming. so did someone else.
witt. you get my pm yesterday?
Old Mar 20, 2008 | 12:28 PM
  #504
Witt's Avatar
Somewhere around 23 psi should be 5v on the MAP iirc.
  #505
lsjwannabe's Avatar
The car is absolutely a different car now.
  #506
Witt's Avatar
Yeah, I have to dig up some parts and see what is usable and what isn't for ya.
Old Mar 20, 2008 | 12:29 PM
  #507
Herndon_High_SS's Avatar
Little more detail on that?
Old Mar 20, 2008 | 12:31 PM
  #508
lsjwannabe's Avatar
It makes my 2.5 pullied setup seem like it was stock
Old Mar 20, 2008 | 12:32 PM
  #509
nice man
  #510
That's what I like to hear.
Old Mar 20, 2008 | 12:33 PM
  #511
Witt's Avatar
Just a little FYI for those on stock engines. I only ran the car for about 15 minutes after installing it but with the 3.34" (85mm) pulley, it seems to make about as much boost as the 2.8" M62 did assuming my boost gauge is somewhat correct. I have no data to compare yet as I had other things I had to do last night afterwards, I'll have something for you guys today though.
  #512
^sweet.
Old Mar 20, 2008 | 12:34 PM
  #513
lsjwannabe's Avatar
my boost gauge just sits at 20 pretty much
Old Mar 20, 2008 | 12:35 PM
  #514
Omega_5's Avatar
Originally Posted by 2K5SS/SC?
I thought our MAP sensor was a 2.5bar sensor or is it a 2.0bar which should cover what the blower is belting out?
The MAP is a 2.5 bar gauge, or 3.5 bar absolute, so.. ~36psi is the max of the sensor...
What the ECU reads to... I have no clue.
http://www.bosch.com.au/content/lang...d_Function.pdf
Old Mar 20, 2008 | 12:36 PM
  #515
lsjwannabe's Avatar
yeah 36.80 according to a few pulls
Old Mar 20, 2008 | 12:37 PM
  #516
Raven SS's Avatar
36.80 psi?
  #517
lsjwannabe's Avatar
yeah the map also takes atomspheric pressure 14.7 in to it
  #518
Witt's Avatar
If you have the latest version of HPTuners they fixed the MAP scaling after a year of nagging them about it. Stock MAP should show 270.59kpa at 5v. Comes out to about 24.5psi when the over voltage code should trip.
Old Mar 20, 2008 | 12:39 PM
  #519
Omega_5's Avatar
Good deal.
270.6kpa sounds about right, considering the overshoot that Bosch allows for...
  #520
Raven SS's Avatar
******* christ this thing is pushing 36psi
Old Mar 20, 2008 | 12:41 PM
  #521
Witt's Avatar
Anybody have specs on the stock supercharger mounting bolts? (thread pitch, length, diameter?)
Old Mar 20, 2008 | 12:43 PM
  #522
**** I had em in my car yesterday, but I think they are 10mmx1.5x2.5" under head or something close to that
Old Mar 20, 2008 | 12:44 PM
  #523
Area47's Avatar
Rent me! per hour
the only time i hit 20 psi was when it was 5 degree's out with a 2.7
yikes.
i knew i should have jumped on this in the begining
Old Mar 20, 2008 | 12:45 PM
  #524
pjk91's Avatar
check the 2.4 s/c how to thread--listed there
  #525
damn makes me wish I was still s/c'd... oh well maybe I'll swap btwn for street an track lol
