Fuel Cooler
Old Aug 28, 2011 | 02:15 AM
BryceL61's Avatar
Fuel Cooler
What dos eeveryone think on installing one of these inline of our fuel system like right before the fuel rail? Providing a bit of extra benifit of cooler fuel.
Heat Sink
wonder what would be required in fitting this inline?
Old Aug 28, 2011 | 02:43 AM
cobaltss#01's Avatar
You could maybe wrap the fuel line with some kind of insulating material also.
Old Aug 28, 2011 | 04:24 PM
Leafydialupking's Avatar
He, my fuel rail and the metal lines near it get the most head soaked just form touching the head. Having a plastic fuel rail and some insulated lines would do more than that heat sink could.
Old Aug 28, 2011 | 07:40 PM
CanadianCobalt's Avatar
What does it matter if the fuel is colder? Condense more through smaller injectors?
Joel
Old Aug 28, 2011 | 07:49 PM
Joel
Cools the air charge a little bit more.
Old Aug 29, 2011 | 03:58 AM
BryceL61's Avatar
Joel
also less change of pre-ignition, better fuel economy etc. heat is always the enemy of engines.
Ive warped mine in the cool tape stuff but im more or less interested in the type of fitting on our fuel rails and if it detachable and i can add a cooler like this inline with maybe just an adapter or something right before the fuel rail? The fuel system is the only area on our cars i haven't dived into in depth. only thing I've done is filter change, even when i did full rebuild myself i didn't touch it just moved it aside. a -8an fitting or something like that from jegs or napa or whatever.
Old Aug 29, 2011 | 04:07 AM
Berto09ss's Avatar
im interested in seeing this on a Balt
Old Aug 29, 2011 | 04:26 AM
Omnigear's Avatar
fuel cooler= e85 ^_^
Old Aug 29, 2011 | 04:39 AM
this-is-it-ss-05's Avatar
Heat Sink
http://www.barrygrant.com/fromBarryG...ink-178002.pdf
Old Aug 29, 2011 | 04:50 AM
defo98's Avatar
Someone should test this out
Old Aug 29, 2011 | 10:11 AM
mrbelvedere's Avatar
dont waste your money det some dei fuel line wrap for over the valve cover
Old Aug 29, 2011 | 06:31 PM
BryceL61's Avatar
it cant hurt to try it, im definitely going to put one on if I can figure out what fittings I need i'm not quite sure how the fuel line attaches to the fuel rail on our cars. Ill look into it a bit more and maybe post up what I come up with. it would be done inline right before the fuel rail on our cars.
Old Aug 29, 2011 | 06:34 PM
Save your money, and it can hurt by making more fuel connections that could possibly leak.
Old Aug 30, 2011 | 12:21 AM
defo98's Avatar
make sure its not leaking before you go out and do a run...
Old Sep 18, 2011 | 05:04 PM
Malaclypse's Avatar
There's no point in this really. Cobalts use a returnless fuel system. That means that any heat gain that can happen will be in the fuel rail and under the hood. That's pretty much it. If you want to, wrap the rail in gold foil. Like this: Aaron's fuel rail mod - GrandAmGT.com Forum
A fuel cooler is useful for older return style systems that would return hot fuel to the tank.
Old Apr 22, 2024 | 01:53 PM
breakinfbad's Avatar
Welcome!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
