Harrop HTV1320-LSJ using Eaton TVS technology
^^lol Dan^^^
Best I can do:
http://i30.tinypic.com/4li0c6.jpg
http://i31.tinypic.com/287q8oh.jpg
http://i31.tinypic.com/35b6laf.jpg
http://i31.tinypic.com/fp09kp.jpg
http://i26.tinypic.com/dzj7r8.jpg
Best I can do:
nope neither worked...and i bet dan was being an ass..lol...dont worry i'll get u
*edit* i can see dans pic...ima get u sucka
*edit 2* pics work thanks witt just take forever to load up
Let's see return fuel system, 70lb injectors, built tranny, clutch, new axles, summer tires, headers, heat exchanger, springs, port & polish, pistons, cams, head studs, our rods are good to 450hp right, if not rods are 400 we do have the forged rods, but a 8k redline
, it might get risky, also maybe investing in lowering my final drive for longer gears, the tool isn't very expensive
. With the higher revving motor do u thionk i should drop compression to 8.5:1 to be on the safe side with the amount of boost this S/C can push, or is our stock stroke sufficient enough.so anything else to support 400 crank with this S/C? Oh yeah a tune. I'll feel safer on 70 lb injectors than 60 just in case
That's my list and it's complete with this S/C, and i was thinking of doing the m90 swap
. Keep up the good work Guys at Harrop
