Harrop HTV1320-LSJ using Eaton TVS technology
Old Feb 9, 2008 | 01:28 PM
  #751
06blackg85ss's Avatar
yeah mine is quite a bit different now since I had a chance to actually sit down and dial it in. Need to adjust it some more, but I waiting to fix the fuel issue so I can run a little more timing up top
  #752
an0malous's Avatar
i must be weird. im the opposite.
I find dialing in mafs pes etc etc quite straightforward
timing I find tedious and frustrating heh.
Old Feb 9, 2008 | 01:30 PM
  #753
Witt's Avatar
Same here, overreacting knock sensors for the lose.
Fuel goes where I tell it to, no issues on what "might" happen if too much or too little is used, albeit nothing stupid is commanded.
Old Feb 9, 2008 | 01:31 PM
  #754
Raven SS's Avatar
its almost march...come on harrop!!
Old Feb 9, 2008 | 01:36 PM
  #755
2K5SS/SC?'s Avatar
Oh, I do hate those over reactive knock sensors especially since the car senses knock sometimes even when it's not there! I found that out on the dyno and was pretty pissed! HPTuners has some control to reduce it, but not much.
Old Feb 9, 2008 | 01:41 PM
  #756
shabodah's Avatar
Can't you lower their sensitivity to a decent level?
Old Feb 9, 2008 | 01:43 PM
  #757
weird cause I get absolutely no knock even when my car gets a little lean (I know the sensor still works though cause I've advanced the timing more to to see)
Old Feb 9, 2008 | 01:54 PM
  #758
2K5SS/SC?'s Avatar
You can lower the amount of timing it pulls and how quickly it bounces back if I remember correctly. It's been awhile since I messed around with the settings.
Old Feb 9, 2008 | 01:58 PM
  #759
shabodah's Avatar
On the LS1's you can change the amount it takes for the sensors to notice knock before any timing is pulled.
Old Feb 9, 2008 | 02:04 PM
  #760
2K5SS/SC?'s Avatar
Yeah, my tuner that taught me contacted the owner of HPTuners directly while walking his dogs. They said that they were going to put that same adjustment in the next version of of HPT, but I heard there will be no more updates unfortunately unless the last one got. The LS2 GTO guys were having the same issues, and that solved it for them.
Old Feb 11, 2008 | 05:27 AM
  #761
Harrop's Avatar
Originally Posted by Super_SS
anything over 350whp requires a return line...on almost any car to function properly
Someone forgot to send me that memo ... so I've only got ~650rwhp without a return line.
Almost March ????? I'm one day ahead of you (well ... ~18hrs), and it's not even half way through February in Aussie yet.
BTW ... I did not state what year we would release it, I only mentioned the month. March 2009 ??
Perhaps these will help ease the tension ...
Old Feb 11, 2008 | 05:31 AM
  #762
supercharged414's Avatar
I can't wait to get my hands on one of those...
Old Feb 11, 2008 | 05:50 AM
  #763
DoubleLP's Avatar
Wow that looks awesome! I can't believe I have missed this thread so far....not anymore!!! Subscribed!!
Old Feb 11, 2008 | 06:56 AM
  #764
damnit no pics at work
Old Feb 11, 2008 | 07:06 AM
  #765
Witt's Avatar
They're gallery pics from here. Theres some posted over on the redline forums in that gallery too.
BTW Paul, did you end up picking up a set of those disc style 79lb/hr injectors? I ordered a set this morning for this blower and I'm just wondering how long delivery time is from racetronix.
Old Feb 11, 2008 | 07:48 AM
  #766
2K5SS/SC?'s Avatar
Damn that **** looks hawt! One step closer!
Old Feb 11, 2008 | 08:19 AM
  #767
Omega_5's Avatar
Very nice... I'm really loving the large throat area...
Old Feb 11, 2008 | 08:22 AM
  #768
redlineblueline's Avatar
its like pr0n for cars
for some reason i am doubting thats a 4 cylinder
Last edited by redlineblueline; Feb 11, 2008 at 08:22 AM. Reason: Automerged Doublepost
Old Feb 11, 2008 | 08:27 AM
  #769
06black's Avatar
Witt
RC makes some awesome ~80lb/hr injectors that'll work with our style and impedance drivers if you need a set.
i picked up a set for my car to help cover the head/cam package once it gets a bit nicer out.
Old Feb 11, 2008 | 08:39 AM
  #770
Witt's Avatar
Witt
The next size up I could find from them were 750cc (71lb/hr) and they don't state any flow numbers or even what type (disc,pintle,ball).
The ones I picked up from racetronix are 850cc (79lb/hr) disc style with better min. flow rates then the 660s most of us use. Also racetronix are 100 bucks cheaper for the set.
Old Feb 11, 2008 | 08:50 AM
  #771
06black's Avatar
i snagged a catalog of theres from a local shop and started tearing thro it. it was a old book so things might have changed but i sure hope not. i've had tons of luck with big RC's on DSMs and good ole B18s
i dont have it on me at work, but i swear i saw a set around that flow(once you converted to 58psi from the measured 43)
i called them to verify injector type and impedance and every thing checked out, it was a bit ago tho, the 60's with the OE head have been ok as of yet.
but meh, if you got these others for cheaper then its no big deal, just wanted to put it out there.
Old Feb 11, 2008 | 09:01 AM
  #772
Witt's Avatar
Just the fact that these ones I bought are disc style over the shitty pintle 660s were enough for me to buy them.
I actually expect better injector control with these. We'll see though.
Old Feb 11, 2008 | 09:11 AM
  #773
06black's Avatar
pen tip style FTW.
they only leak a little.......
Old Feb 11, 2008 | 10:28 AM
  #774
an0malous's Avatar
yay. someone agrees with me!
Old Feb 11, 2008 | 11:08 AM
  #775
zinner's Avatar
Moderator Alumni
You only made 2 of them!!!
