Harrop HTV1320-LSJ using Eaton TVS technology
Old Mar 7, 2008 | 09:18 AM
  #1176
Deathscythe's Avatar
[QUOTE=USMCFieldMP;2047739]There is no way that you can make that blower look anywhere close to stock... other than the color.[QUOTE]
I don't care about the overall size difference but most people won't know the difference just by looking at it. It'll still be a sleeper to most even though the change is right in front of your face.
Old Mar 7, 2008 | 09:20 AM
  #1177
RL-2005's Avatar
no its definitely a dark gray powder coat not a true Black
if these people are looking under your hood they will either have no idea the car is supercharged or they will notice right away it is a non-stock blower. those are the two groups of people I have come across
Old Mar 7, 2008 | 09:23 AM
  #1178
Omega_5's Avatar
I've noticed that too...
Most just want to check what pulley your running..
Old Mar 7, 2008 | 09:30 AM
  #1179
ColeJJones's Avatar
Bannned
are those 4 screw or 5 screw pulley hubs on the tvs?
hopefully 5 screw. and if not hopefully the same size as the pulleys that everyone else sells so we dont have buy through them
Old Mar 7, 2008 | 09:34 AM
  #1180
RL-2005's Avatar
I'm sorry but a company finally comes out with some seriously engineered and quality parts and you are worried about where to get cheaper pullies? C'mon the least you could do is support a company that gives a **** about the LSJ.
Old Mar 7, 2008 | 09:43 AM
  #1181
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by Omega_5
Maxing the output frequency.
When you start moving more air by the MAF, than it can handle... it gets a bit upset.
Maybe I'm thinking of a different car's MAF, but I thought ours could handle plenty of air. In fact... I think that Hahn's GT35R kit uses the stock MAF, IIRC. Maybe I am mistaken.
Old Mar 7, 2008 | 09:48 AM
  #1182
redlineblueline's Avatar
they had said in this thread already that the pulleys are going to be availible through them only
Old Mar 7, 2008 | 09:52 AM
  #1183
I guess you're right, most people here in va beach only know what a turbo looks like. Then they ask me why my car screams like a banshee when I pull off. In any case, I look forward to this addition.
Old Mar 7, 2008 | 10:08 AM
  #1184
freakta's Avatar
i read some of this i skipped some of it. it looks like a great piece and looks like it will make some power. any numbers on anything yet? how much who how many hp tq boost max rpm anything
Old Mar 7, 2008 | 10:10 AM
  #1185
lsjwannabe's Avatar
none yet, i am testing so is witt and raven ss, we will post up all the info you could ever want.
Old Mar 7, 2008 | 10:27 AM
  #1186
Area47's Avatar
Rent me! per hour
hmmmmm interesting to say the least.
just wish i would have jumped on this when i had the chance.
the dsm trick does work, but you also lose accuracy
Old Mar 7, 2008 | 10:28 AM
  #1187
06black's Avatar
who needs low speed resolution.....hell, who needs resolution at all!
WOT or fail.
Old Mar 7, 2008 | 10:30 AM
  #1188
lsjwannabe's Avatar
maf's are for loosers anyway
Old Mar 7, 2008 | 10:33 AM
  #1189
06black's Avatar
TRUE!!!!
but we lack the needed tables for SD...well a full SD tune that is.
Old Mar 7, 2008 | 10:34 AM
  #1190
Omega_5's Avatar
Yeah... more of a band-aid
But hey... wasn't that what DSM's were all about?
Old Mar 7, 2008 | 10:35 AM
  #1191
Band-aid's are for queers.
Old Mar 7, 2008 | 10:37 AM
  #1192
Witt's Avatar
You can push the stock MAF to about 13k hz before clipping occurs however the software only allows adjustment to 11.1k.
You lose resolution whether you increase pipe diameter with the stock MAF or replace it with a larger unit.
Old Mar 7, 2008 | 10:39 AM
  #1193
lsjwannabe's Avatar
resolution is overrated anyway
Old Mar 7, 2008 | 10:44 AM
  #1194
Area47's Avatar
Rent me! per hour
just because i was one of the few here in town that didn't switch to a 2g mas, or a gm maf-t setup. doesn't mean i bandaided the stock mas
honeycomb removal + tin snips + screw driver = no fuel cut. ever
hehehehehehhehe
  #1195
06black's Avatar
the larger MAF would be calibrated to have spec'd resolution if it was designed for such...no?
Old Mar 7, 2008 | 10:48 AM
  #1196
2K5SS/SC?'s Avatar
Wow those blowers look great Harrop! The one without the paint in natural aluminum finish, can that be had for the same price? Looks almost identical to stock and that what I would want.
Old Mar 7, 2008 | 12:44 PM
  #1197
TVS_SS's Avatar
Unless harrop gives them the proper dimensions, aftermarket companies will be "guessing" as to the correct offsets and fit diameters. Do not skimp out and purchase a "cheap" pulley because it will come with a high risk of being incorrect. If your spending the money to mod your car.. at least make sure its done CORRECTLY.
Old Mar 7, 2008 | 12:46 PM
  #1198
Area47's Avatar
Rent me! per hour
this right here. is a key to lsj survival.
cheap parts equal cheap results.
Old Mar 7, 2008 | 01:22 PM
  #1199
Raven SS's Avatar
friends don't let friends buy cheap parts
Old Mar 7, 2008 | 01:26 PM
  #1200
BRN169's Avatar
I'm not in this to build an all-out strip burner, if that was the case I would dust of my '89 T/A and dump cash into that. I want this to be an economical daily driver with some sleeper like get-up when I need it... That said MAF resolution is everything to me... I would be happy to buy a TVS to make the same power I am currently making (262whp @ avg. 29.9mpg) if I could make it more economically... 265whp @ 33-35mpg would put as big a big-ass grin on my face as 300whp @ 29mpg would...
