Harrop HTV1320 Supercharger...
Old Mar 6, 2008 | 01:17 PM
Scythe_Snake's Avatar
Originally Posted by Witt
I have Racetronix 79lb/hr ones installed right now in anticipation for this blower. My logs will be reflected with such injectors.
Even better. I look forward to how your logs will compare to the others'.
I take it you have an intake and full exhaust already, as well as cams?
Old Mar 6, 2008 | 01:19 PM
Josh@ottp's Avatar
my guess is 60's might not be big enough for the heavy hitters
Old Mar 6, 2008 | 01:20 PM
Witt's Avatar
Yeah already been down that road, forged bottom end w/neutrals, cams and built top end.
I do have a supplemental fuel pump but its not installed as my factory service manuals didn't list which stupid line was supply and return from the tank and I wasn't dropping the tank to find out. I've since grabbed a spare fuel module and found out but if I see a fuel pressure drop I have a spare inline Aeromotive fuel pump ready to be installed.
Old Mar 6, 2008 | 01:24 PM
Ah okay. You'll show some good potential with the TVS with a well built engine then. 79's would probably be too much for an LSJ with mostly stock everything, correct? Or would it matter at all?
Old Mar 6, 2008 | 01:25 PM
Witt's Avatar
After installing the 79s, I wish I would have done it earlier. The pintle style 60s that everybody uses are garbage compared to a disc style injector like the 79s. They have massive overhead and better short pulse fuel control than the 60s imo.
Raven SS's Avatar
I'll be running 60s off the bat and going accordingly. Me and Witt both are on the fully built side of the house
Old Mar 6, 2008 | 01:28 PM
Hmm. At what stage did you install your 79's? Before or after your internal build?
Oh that's right. I forgot you were built as well. Hmm.
LSJ is also built to or am I talking out of my ass? If I remember he is running a 2.5.
SCBLKRL's Avatar
so there is a stock side to the equation as well?
Old Mar 6, 2008 | 01:29 PM
Witt's Avatar
BTW, and this applies to anyone who is test piloting these...If god forbid something would break I have a massive collection of spare LSJ parts in my basement. They are actually mostly djt81185's from his second engine rebuild after he spun a con rod bearing but I'm sure he would let me make a little withdrawl from the bank of Dan's spare parts.
Other than a block, head, and crank, I have everything needed to build another engine if one of us has a booboo. Let me know asap if something happens and we can arrange a little shipping manuever.
Area47's Avatar
Rent me! per hour
I'm fkn giddy.
Heres hoping to not split a sleeve or shatter a con rod.
oooooohhhhhhhhhhhh have fun with that one!
don't pull a dan
Old Mar 6, 2008 | 01:30 PM
  #36
Witt's Avatar
I built the bottom end in April of last year. I installed the 79s in January this year when I applied to be a test pilot for Harrop.
  #37
redlineblueline's Avatar
don't pull a dan
i'm sure there are enough parts floating around pittsburgh to fix any engine related problem
Old Mar 6, 2008 | 01:36 PM
  #38
Raven SS's Avatar
thanks Witt. And lsjwannabe isn't built he's going to be the test pilot for those with stock internals. So he would be the one for questions when it comes to stock engines
Old Mar 6, 2008 | 01:39 PM
  #39
Ah okay. Thanks for the info. If I ever get a **** load of money and get built, I will look to your logs.
Ah okay, I will be looking to LSJ then. Thanks guys for your contribution tot he community. Trust me, there are people who appreciate it.
Old Mar 6, 2008 | 01:43 PM
  #40
Area47's Avatar
Rent me! per hour
someone needs to get off their butt and put their pump in. also needs to install something else to help with "pressure"
Old Mar 6, 2008 | 01:45 PM
  #41
Raven SS's Avatar
Were gonna try seeing how it appears there is only 3 of us(we've been searching for months now LOL) I hope we can answer all question.
Old Mar 6, 2008 | 02:06 PM
  #42
Kibosh3's Avatar
people like me
all i have for this app are 60's...hopefully they shoudl suffice :P
  #43
WSFrazier's Avatar
Can't wait to help install and drive this thing
Old Mar 6, 2008 | 02:35 PM
  #44
chevytech007's Avatar
Bring on the fun!!!
Old Mar 6, 2008 | 02:36 PM
  #45
Raven SS's Avatar
its gonna be fun
Old Mar 6, 2008 | 02:39 PM
  #46
Josh@ottp's Avatar
what are everyones power expectations for their tvs build?
Old Mar 6, 2008 | 02:41 PM
  #47
WSFrazier's Avatar
I know Witt is going to stop @ 400hp, since he is using stock rods still.
Old Mar 6, 2008 | 02:43 PM
  #48
Raven SS's Avatar
ima push it as hard as possible for dyno numbers hopeing for 450+ but for daily driving like high 300s maybe more whatever feels good
Old Mar 6, 2008 | 02:44 PM
  #49
Omega_5's Avatar
... I'm probably going to investing in a TVS this fall.... although I included rods in my build... I had no intentions of going too far over 300.... problem is, I just kept buying parts....
Old Mar 6, 2008 | 02:45 PM
  #50
Josh@ottp's Avatar
now guys we are talking fwhp right?
