HARROP TVS, What You Need To Know & FAQ
Old Jun 1, 2011 | 08:10 PM
  #276
sjc0013's Avatar
Window Licker
Hey guys I had a quick question. Who would you guys recommend as far as tuning the tvs. Im in PA and wanna go to someone who really knows what they're doing and possibly have them install it for me? I wouldn't mind doing it myself but I feel too uncomfortable driving it a long distance to a good tuner. Does BYT know what they are doing as far as the tvs goes?
Old Jun 2, 2011 | 02:19 AM
  #277
InfraRedline's Avatar
I would get ahold of BYT
Old Jun 3, 2011 | 05:30 AM
  #278
freakta's Avatar
Well thats more acceptable for those boost levels. I saw 19psi on the 2.9 with 3" intake, vibrant header, 2.5" dp and 3" catback. Now I have a 3" dp going on
how much did your boost drop when you put on the 3in dp
Old Jun 5, 2011 | 11:47 PM
  #279
the919Phenom's Avatar
Might be getting tvs here soon. Any good tuners in nc???
Old Jun 6, 2011 | 03:04 AM
  #280
I did it at the same time as my ported head, so im not sure. I still havent logged boost with this setup yet lol
Old Jun 11, 2011 | 12:12 AM
  #281
zrated89's Avatar
bump just got mine
Old Jun 30, 2011 | 05:20 AM
  #282
kstorm61's Avatar
im stage 3 right now but want more power and tq this is my set up right now. what would i or could i make to the wheels with this setup and a TVS ?
3.1 pulley or 2.9 for the tvs not sure which one i should run.
current mods 2.9 pulley shorter belt 80lb injectors s3 heat exchanger dual pass end plate option b bkr7e spark plugs zzp mid length header zzp 3inch down pipe stock exhuast ( u grading to a full 3 inch exhuast) making 16psi on a zzp can tune.
what psi can i expect with a 3.1 pulley or 2.9 and a good spot on tune with all the above mods. i have when upgrading to a tvs ?
Old Jul 3, 2011 | 06:01 PM
  #283
OttawaMark's Avatar
Looking into this for my LE5 2.4L Auto, the M62 is clearly limited by its design and they dont call it the Heaton for nothing.
I'm thinking: 3.4 or larger pulley, not looking for crazy boost. Between 10 and 12 PSI, with my 20% displacement advantage and full exhaust 3.4 should put me there.
I'll add Option B, Phenolic gasket, 78# springs and do a Port on the head and add some ARP studs to keep it all together and flowing fast.
Not many 2.4s with the TVS, but I think it can work great if boost is kept lower.
One thing, 5 rib belt on LE5s, do I just run it on the 6 rib pulley wherever it fits best? As in, leave a rib empty on the pulley?
Informed comments welcome, I'm thinking hard about this TVS.
Old Jul 3, 2011 | 08:23 PM
  #284
07cobalt_LT's Avatar
the only issue you might run into with this based in the size if the supercharger and pulley is your front upper crossmember since your auto (correct?)
i know you probably already modified it to fit your m62 but you will probably have to modify it even further to allow for adequate space
Old Aug 15, 2011 | 12:28 AM
  #285
87gn06gto07irl's Avatar
Is porting and polishing worth anything on these?
Old Aug 15, 2011 | 02:08 AM
  #286
freakta's Avatar
the tvs is maxed factory so no porting can be done
as low as your tune lets you go... ive got a 2.5 on mine, a few others are running them as well. i think im the only guy running 60#s with it though, most people go up to 80#s
Old Aug 15, 2011 | 07:44 AM
  #287
gbkglenn's Avatar
how is your car running with the 60#s with the tvs ?
Old Aug 16, 2011 | 10:24 AM
  #288
WickedSS2005's Avatar
Lots of methanol
Old Aug 17, 2011 | 11:52 AM
  #289
freakta's Avatar
Originally Posted by WickedSS2005
Lots of methanol
and then lots more...
4 1#hr injectors, one at each cyl in each port
pumped very high velcity
o ya and a brfpr for the fuel
bigger injectors psssshhh just run the ones i have more efficiently
id love to get some nitrous and run this setup
so i could be the only 4cyl running 12 injectors hahaha
but ill prob just pump it into my intercooler to keep temps even lower than they already are
Old Aug 17, 2011 | 12:06 PM
  #290
nizzle's Avatar
sub'd
Old Aug 17, 2011 | 05:16 PM
  #291
What is the max efficient blower rpm?
Old Aug 17, 2011 | 06:16 PM
  #292
RooTBeeR's Avatar
~12,000RPM?
so on the 80mm pulley would be ~5825 engine rpm
Old Aug 18, 2011 | 01:29 PM
  #293
You sir, have got to have a long discussion with me. I'm outta the loop on so much this year because I've reterted back to the M62
Old Aug 18, 2011 | 01:53 PM
  #294
Pyros777's Avatar
Originally Posted by 87gn06gto07irl
what is the max efficient blower rpm?
22,000
Originally Posted by harrop
part of the durability testing we have done on all our htv range is "extended abuse" mode on our in-house and eaton-certified test cell.
We have run our generic htv1320 at 8,000rpm to 22,000rpm for 100 continuous hours, cycling the bleed valve (boost controller) from 5psi - 25psi every few minutes (its actually a lot more complicated than that).
We have not had any failures while durability testing.
Assuming we had a head that could flow the massive amounts of air it would produce at that speed, this is the pulley size you'd need, and the engine rpm youd have to spin to:
(22,000 * Supercharger Pulley) / Crankshaft Pulley @ 6.25 = Engine RPM)
2.3 @ 8,096 = 22,000 rpm
2.4 @ 8,448 = 22,000 rpm
2.5 @ 8,800 = 22,000 rpm
2.6 @ 9,152 = 22,000 rpm
2.7 @ 9,504 = 22,000 rpm
2.75 @ 9,680 = 22,000 rpm
2.8 @ 9,856 = 22,000 rpm
2.85 @ 10,032 = 22,000 rpm
2.99 @ 10,525 = 22,000 rpm
3.06 @ 10,771 = 22,000 rpm
3.10 @ 10,912 = 22,000 rpm
3.15 @ 11,087 = 22,000 rpm
3.30 @ 11,616 = 22,000 rpm
3.34 @ 11,757 = 22,000 rpm
Edit: Oh you said most efficient, I understood "max rpm". Ah well. lol
While I'm here, figure I'll share this:
This is the TVS performance map converted from Volume to the more familiar Mass using an assumed air density of 0.076 ft^3/lb.
The conversion I used was:
Volume m^3/hr * 0.5885 = Volume ft^3/min
Volume ft^3/min * Air Density ft^3/lb = Mass lb/min
Old Aug 21, 2011 | 12:48 AM
  #295
freakta's Avatar
so what is the rpm range tat the supercharger is most efficient fromi.e. 7k -15k K just numbers.
it wuld be a fun experiment to play with pulley size based on engine rpm to figure driving input, and see what the tvs would be most efficient driving at... or maybe it spast my bed time
Old Aug 22, 2011 | 01:36 PM
  #296
Pyros777's Avatar
Best bet is to pop the car on a dyno and bust out a custom PID to log supercharger speed.
Also, if you trust the conversion to MAF from above, you could do MAF vs pressure ratio (PSI+14.7/14.7) on that chart using data from your log. From there you could compare it to your dyno chart, and you'd be able to see all kinds of data at least regarding what parts of that performance map our cars operate in when theyre making power.
I've done this to a certain extent with the M62 with a dyno log, but I'm not totally convinced its accurate. It is a nice illustration though.
Note: I filtered the log to only show WOT.
Looks like I made ~220whp & ft-lb at 5252rpm, 14.06psi aka 1.97:1 Pressure Ratio, and 10978 s/c rpm. Thats right about 59% efficiency according to the M62 map.
If I had had a better flowing exhaust at the time, I might have made the same power at a lower boost level, thus moving the point inward to one of the more efficient bands on the map.
Old Aug 22, 2011 | 01:49 PM
  #297
nizzle's Avatar
Wow! This is over my head for sure. Seems like detailed info. Wish I knew wtf I was looking at.
Old Aug 22, 2011 | 02:08 PM
  #298
Empty Pockets's Avatar
sub'd
Old Aug 23, 2011 | 09:12 AM
  #299
zfissette's Avatar
serious question, has anyone run a crazy small pulley on a tvs and set the boost limit at 20psi? curious if it can be made to put out a better trq and hp curve than a m62 across the board without generating motor destroying boost at upper rpms. also curious how effective the car is at limiting boost with the bypass valve and how it affects iat2s and such.
Old Aug 23, 2011 | 11:14 AM
  #300
nizzle's Avatar
I didnt know you could set a boost limit on a SC. In addition, as long as you have a good tune and a couple supporting mods, you wont hurt your motor with it. I've got a 2.7 pulley on my TVS.
