Injector choice w/ 2.2 Patriot Head??
I have the patriot head on my L61 and im running gm stage 2 42# injectors. i believe the injector ports on the patriot head are bigger than stock and i cannot get the damn spacers (I guess thats what they're referred to) to seal properly to save my life. I've tried different o-rings but there is still alot of play with the spacers sitting in the injector ports.
are there any injectors out there that would work without the use of spacers or maybe a longer injector? advice? switch to an LSJ fuel rail maybe?
My car runs like **** because I cannot get the damn things to seal
replace them for...? is there a larger size available?
koo, hope so
yep, never really solved it completely...idk if I should give fresh o-rings a try.
nope no retune since then...i wish the car ran better but can't say it does
09-28-2015 12:51 PM
