inline fuel pump?
Old Mar 11, 2008 | 01:16 PM
jimbos'ss's Avatar
Originally Posted by Raven SS
yea but witts running them with no probs so far so will see
all he did was swap the injectors and tune for them right? or did he change any other parts.
Old Mar 11, 2008 | 01:24 PM
Raven SS's Avatar
swapped them into the 60s harness and tune for them...u have a pm
Old Mar 11, 2008 | 01:26 PM
Red2.4SS's Avatar
I would be afraid of starving the last cylinder at least. Hope it works for him though. That would make it easier. I wouldn't trust it though.
Witt has an extra fuel pump. I was afraid of the pressure not going down properly at idle due to the large volume trying to be returned!
Old Mar 11, 2008 | 01:27 PM
Raven SS's Avatar
yea were working that out right now...everything is being monitered all the time
Old Mar 11, 2008 | 01:33 PM
Red2.4SS's Avatar
RETURN SYSTEM is the proper way to set up the fuel system for more than 300-350 whp. You are just risking your engine otherwise IMO.
Old Mar 11, 2008 | 01:34 PM
Raven SS's Avatar
lol like i said...i know..but im broke because of the stupid engine...
Old Mar 11, 2008 | 01:40 PM
Red2.4SS's Avatar
Yeah, but imaging having to build a new engine cause you go lean and fry it?! That is what I am saying. I have learned in the past that you have to finish the entire build properly or you will only have problems. Either with parts breaking or things just not running like they should.
Old Mar 11, 2008 | 01:43 PM
Raven SS's Avatar
i dunno i think it will be fine for now..so do ALOT of the knowledgable people on here...but deff gonna upgrade soon
Old Mar 11, 2008 | 01:48 PM
Red2.4SS's Avatar
I'm not saying it can't do it, I'm saying I wouldn't bet on it if it were mine!
I have never actually tested OEM flow/pressure maximums. So I can't honestly say it will reach a maximum safe flow of 200L/hr @ 58psi
I wish I knew cause I am trying to figure out how far I can stretch the OEM in tank pump!
My concern is that fact that when the system is set to maintain 58psi at the tank in the returnless setup and you are flowing 3X's the fuel in the system I would worry that the pressure would drop at the rail.
If you are monitoring it constantly and see no proplem then it should be OK.
Old Mar 11, 2008 | 01:49 PM
Raven SS's Avatar
thats why people like me and u are test dummys lol
Old Mar 11, 2008 | 01:52 PM
  #36
Red2.4SS's Avatar
Yep, blow up and waste $1000's to tell others what not to do!
Old Mar 11, 2008 | 06:17 PM
  #37
jimbos'ss's Avatar
i'm gonna have to pass on that one
Old Mar 14, 2008 | 12:54 AM
  #38
Witt's Avatar
yah but the question is will our pump be able to push enough volume and pressure to make use of those injectors. i know witt is currently working on that right now. personally i think the 60lbers are more than capable with the right setup.
With a compressor swap they won't without a supplemental pump.
I doubt it would cost more than $400 to convert leaving the factory fuel pump for now. If you can. You demands are higher than mine.
No point in swapping if you are goin to leave the fuel pump stock.
Those are some BIGGG injectors to not have control of the rail pressure! The last cylinder on the line could have trouble!
Regulator has control of the rail. Fluid dynamics are much different than gas.
See above.
Pressure relief above 3 bar is much less due to the amount being relieved in my experience at that high of a pressure.
Results = truth Wait till I have solid proof in the next couple of weeks.
Old Mar 14, 2008 | 12:58 AM
  #39
jimbos'ss's Avatar
i will be patiently
Old Mar 14, 2008 | 01:03 AM
  #40
Red2.4SS's Avatar
I swaped to a return system so I can change the fuel pressure and keep the fuel in the fuel rail cooler. I had bad vapor lock last summer in 100*+ heat.
And if the flow becomes great enough the rail pressure will drop off. I suppose this would mostly be caused by a failure of the pump to keep up however.
I also had this problem when my fuel filter became clogged.
Old Mar 14, 2008 | 02:00 AM
  #41
Witt's Avatar
Either failure of the pump or a restriction of the fuel supply line would cause the problem you are describing.
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
