jimbos'ss turbo build
#328
#332
yah that shouldn't be a problem. do you have a progressive controller or a boost controller like mine? and are you running the lines off the windshield washer reservoir or do you have a trunk mount kit?
what 06black was telling me before was to run 3" from the maf straight to the tb, but keep it short like 5 or 6 inches so it doesn't effect pr building. which means i have to lengthen the harness for the maf(no problem for me). thanks for the info on the vacuum. but is that in hg or psi. i have to purchase a new spring for my bov, and i needed someone with a similar setup to guage from.
Im running the boost controller, and im gonna run it from the winshield washer res. no i don't have the trunk mount. theres alot of wires and stuff i just want to make sure it goes in right. lol
#335
#337
one other question, you running it pre or post blower? and do you have a spacer thats allready tapped for a meth nozzle? the reason i ask is i have a spacer that fits between the throttle body and the blower thats allready been tapped and has a meth nozzle in it. but i can't use it for my setup.
#339
#342
#344
#348
