jimbos'ss turbo build
thanks man
ebay, but be mindful of a few things.
1. size-don't go any larger than 28x8x3.5 thats the largest that will fit without notching the bumper.
2. pressure drop
3. max cfm flow.
4. inlet/outlet diameter.
2. pressure drop
3. max cfm flow.
yah i know you gotta pay to play, i'm gonna have to wait on this upgrade for a bit though, the log stays for now.
ok....the cfm shouldnt matter just as long is its up in the 500-600 range....at least for what i plan to do...and inlet and outlet diameter shouldnt really matter as long as it isnt too big or too small...im plannin on 3" so i gues somewhere close to that...and as for pressure drop...i never seen them list that on ebay
takes more air to build a pressure over that larger area VS a 2.5in unit.
PD(pressure drop) is the 2nd most important piece of information, the first piece being fin density / weight.
more=better
edit: when you say pressure drop are you refering to the the psi lost when going through the intercooler itself?
when you say 2.5 are you talking about the thickness of the core or the size of the piping...as far as piping goes i dont think i should have a problem with 3in...i plan to run to 300+hp so i think that the piping should do it...not sure i follow you on the pressure drop and fin density...could you explain a bit more?
you want a HEAVY, thick, short core with a 2-2.5in inlet-and outlet (what ever size your turbo outlet is)
the biger the outlet you go the more lag your going to create. there are plenty of guys with allot more power then you want with a 2.5in IC inlet/outlet.
the short core helps with a minimal PD and if its heavy its got more thermal mass, both vary good qualities.
argggg....RESEARCH!
http://www.turbobygarrett.com/turbob...o_tech101.html
http://www.turbobygarrett.com/turbob...o_tech102.html
http://www.turbobygarrett.com/turbob...o_tech103.html
here's some stuff to look into for more info, compliments of 06black
lol i know....i mean i know whats going on and i know the basics....ive just really never heard anything about intercooler...i guess its a learning progress...i appreciate the help none the less
actually no i'm just giving you those as good reading, they were given to me and have been quite informative sofar. no it doesn't cover intercoolers, but has a lot of good info, i figured you'd get some useful info out of it like i did. if you have allready read it then someone can see it in this thread and read it. i will look into finding a good link o n intercoolers as well and post it in this thread for everyones use. i based my intercooler sizing on the 4 things i listed above. the reason i used 2.5inlet/outlet was because of air velocity. the smaller diameter the higher the velocity, the intercoller itself is going to slow it down a bit. when it comes out of theother side of the intercooler it will transition into 3' piping from there to make sure i don't max out the maf sensor as the freq max is 11,000 in hpt. i'm hoping for the best posiible flow with this setup.
it looks like a really nice one and its not too badly priced
ok,wasnt trying to get on you or anything...i just honestly didnt know anything about intercoolers and thought maybe you could help me, which you did, and i appreciate it. just wondering how much you spent on your intercooler? i found a damn nice one:http://www.treadstoneperformance.com...R6+Intercooler
found a good link on intercoolers, it's slightly biased to the manufacturer, your gonna have to scroll down the page away to get the good info.
http://www.are.com.au/techtalk/intecoolersMR.htm
and dont forget, BOV BEFORE the maf, venting metered air = THE LOOSE
the bov can be close to the maf, as long as its before it.
it looks nice, is of bar and plate design, it will fit, can flow a max of 600cfm, pr drop is less than 1 psi, probably @12psi off the turbo. and the il/ol diameter is 2.5. would work for me.
what would i benefit more from...keep in mind im a 2.4....2.5" or 3"? ive been told to go 3"...but if i would profit more from 2.5" then ill go with that
ok so should i relocate the maf to right befroe the tb, that way i can keep it at 2.5 alot further. that way i keep the maf in a 3" area while keeping most of the piping 2.5. i was planning to keep the maf in the factory location and running the 3" piping way before that to give space for the air velocity to slow down.
the more 3in pipe the more lag, end of story.
in the right hand corner of my screen.
