jimbos'ss turbo build
Old Feb 7, 2008 | 02:13 AM
  #226
Mnatvyc1223's Avatar
Originally Posted by IonNinja
since you guys are on the topic of intercoolers...
isn't the surface area more imortant than thickness? so a much taller and thinner intercooler is more efficient than a short and thick one...
no. from my understanding it should be the same...
basically the same volume...
Last edited by Mnatvyc1223; Feb 7, 2008 at 02:13 AM. Reason: Automerged Doublepost
Old Feb 7, 2008 | 09:21 AM
  #227
06black's Avatar
no.
many experts and the math agrees that the longer the IC the less efficient it becomes per its given size, and a larger PD occurs across it.
a, short, yet thick core will perform better then a long, thin unit.
the guys at Garrett and Precision all say that once your past the first foot or so in length the IC becomes fairly useless.
so take that first foot or so and make it thick. giving you your surface area back while maintaining a minimal PD.
but all this pales in comparison to the thermal mass of an IC. you want the heaviest unit you can get, that usealy equates out to a larger fin density and a larger thermal mass.
that means that the IC can store the heat your IATs give to it and dissipates it at a later moment in time.
so basically you'll heat it up during a run, and the IC will soak up all the heat it can and then "give it away" back to the atmosphere on your drive back to the staging lanes.....ya dig?
a light unit dont have the mass to store all that heat so its forced to absorb less and less heat until it can drop its temp back down.
Old Feb 9, 2008 | 01:22 PM
  #228
2K5SS/SC?'s Avatar
06Black, about how many inches of pipe would you say is the 3" part of the charge pipe you run? Is the rest 2.5" pipe under the car? I use 2.5" all the way on my Integra and it works great and spools fast, but I don't have a MAF in that pipe to worry about either.
Old Feb 9, 2008 | 07:15 PM
  #229
06black's Avatar
about 6-8in
Old Feb 9, 2008 | 07:41 PM
  #230
SSdan's Avatar
roffle at your sig.
"custom intake and a garret exhaust."
Old Feb 10, 2008 | 05:46 AM
  #231
2K5SS/SC?'s Avatar
Originally Posted by 06black
about 6-8in
Thank you. That's I think is the last little bit of the puzzle I've been putting together!
Old Feb 10, 2008 | 07:02 PM
  #232
06black's Avatar
myself and others have put the needed info out there from us doing all the work, ya'll just gotta search to find it
Originally Posted by SSdan
roffle at your sig.
i figured some one would like it.
Old Feb 10, 2008 | 09:02 PM
  #233
ptrblkz24's Avatar
Good **** man,looks like its coming along nicely.
Old Feb 14, 2008 | 02:11 AM
  #234
jimbos'ss's Avatar
ooooooohhhhhhhhh goodies!!!
a couple of the motor parts just arrived, more to come very soon.
Old Feb 14, 2008 | 02:17 AM
  #235
Jusday's Avatar
ooo i love goodies! lol.
Old Feb 14, 2008 | 02:24 AM
  #236
jimbos'ss's Avatar
me too, i've got more on the way too.
Old Feb 14, 2008 | 02:28 AM
  #237
Jusday's Avatar
oh by the way did a guy call you today for info on parts you were selling? he contacted me last night and told me he wanted to buy from you.
Old Feb 14, 2008 | 02:31 AM
  #238
jimbos'ss's Avatar
yah he was the guy i sold the header and dp too.
Old Feb 14, 2008 | 02:37 AM
  #239
Jusday's Avatar
ok cool. glad i could direct him the right way then
Old Feb 14, 2008 | 02:44 PM
  #240
jimbos'ss's Avatar
thanks, i just shipped it out to him.
Old Mar 1, 2008 | 10:03 PM
  #241
chevytech007's Avatar
pics
straight from aas tuning!
Saab intake manifold swap! custom throttle body adaptor drilled out bolt holes and a custom sensor mod to make it fit!
Old Mar 1, 2008 | 10:16 PM
  #242
jimbos'ss's Avatar
wow that adapter is thick, well at least i can drill and tap it for a meth nozzle.
Old Mar 1, 2008 | 10:24 PM
  #243
It has to be that think for all the bolts and everything but it will clear everything fine I will have to extend your TB wiring!
Old Mar 1, 2008 | 10:28 PM
  #244
jimbos'ss's Avatar
thats cool, btw did you get that part number on the rings so i could get it to aaron?
Old Mar 2, 2008 | 12:11 AM
  #245
RooTBeeR's Avatar
Just think of it as a throttle body Spacer lol
HEY! HEY! Lookin' Sharp Jimbo!
Old Mar 2, 2008 | 12:31 AM
  #246
MVP's Avatar
MVP
cool jimbo this should get you to 300+ WHP.
keep up the good work bro.
Old Mar 2, 2008 | 03:00 AM
  #247
jimbos'ss's Avatar
300plus at a minimum
Old Mar 2, 2008 | 11:11 AM
  #248
BlackSS/SC's Avatar
Nice intake manifold. I'd probably go with one like Hahn makes though if I was doing the swap.
Old Mar 2, 2008 | 11:14 AM
  #249
Luv2Race's Avatar
Yea def. 300+ im only on 18 psi running 320whp!
Old Mar 2, 2008 | 11:21 AM
  #250
MISSMATCHEDFACES's Avatar
on what kind of dyno
