LSJ Mini Build ;)
Old May 29, 2012 | 08:38 PM
100% METH's Avatar
if you have E85 and a good reliable tune, you can deff pull it off man. with meth, meh.... it can be done but i wouldnt trust meth as much as E
Shenanigans
Old May 29, 2012 | 08:43 PM
jonathan923's Avatar
^^^ haha oops!
Old May 29, 2012 | 10:03 PM
rcorona8's Avatar
Does any one knows wat is the easiest way to instAll bs delete with motor in car?
Old May 29, 2012 | 10:07 PM
FrossB's Avatar
Thread Killer
I came into this thread hoping your were putting an LSJ into a Mini lol but regardless...this looks like a nice little build!
freakta's Avatar
Originally Posted by rcorona8
Wats ur set up and how do u like it.
Fyi, im on my phone and.cant see your sig....if u haf ur set up there.
tvs 2.8, direct port meth, air to air, exhaust ported head, bolt ons... 320whp 7k
now 2.5 custom cams on the way, springs, nbs, ls4, more revs prob 9k.
head gasket blew on dyno pull so i am buying a bunch of stuff
Sunburst_SS's Avatar
if you remove the right side engine mount, lower the engine down......and support the subframe with a jack and remove the right side subframe bolts....you can lower down the subframe and should have enough room. I've swapped several sets of balance shafts that way. Not sure what is involved in the delete kit though.
Old May 29, 2012 | 10:19 PM
ebristol's Avatar
I like this build.
Old May 29, 2012 | 10:31 PM
euthanasia's Avatar
Rudy 2.4 pulley, 100% Meth with a 20+gph nozzle lol
Old May 30, 2012 | 02:11 PM
rcorona8's Avatar
Ok thanks. Imma try this tonight....i really need a day off to get some work done......
Jaja...have fun....
Old Jun 5, 2012 | 04:46 PM
rcorona8's Avatar
Fak. Im having.trouble lowering the frame to install bs delete kit. facing the, I already removed the left upper motor mount, I.remove the bolts on the left side of the frame and I still can get the motor down. Help.....
Old Jun 5, 2012 | 04:50 PM
  #36
rcorona8's Avatar
Old Jun 5, 2012 | 08:08 PM
  #37
rcorona8's Avatar
Old Jun 5, 2012 | 08:10 PM
  #38
rcorona8's Avatar
Since im removing the stock bs, I dont need to time it correct? Other then the cams.........corret?
Old Jun 5, 2012 | 09:00 PM
  #39
ItalianJoe1's Avatar
Correct, the neutral shafts don't need to be timed.
For that much work I would have just pulled the whole thing out, not really that much more work and much easier to work around, build it clean out of the car and put the whole setup back in already built. I did that on an LNF, much easier to rig all the turbo parts and such on an engine stand than in the car.
Old Jun 5, 2012 | 09:01 PM
  #40
TurboTechRacing's Avatar
Sounds like a great time!
Old Jun 5, 2012 | 09:26 PM
  #41
rcorona8's Avatar
the car.
I guess I learned the hard way......if I were to do it again, I would defenetly take the motor out.
Old Jun 5, 2012 | 10:17 PM
  #42
Dart_SI's Avatar
come to kansas. id like to see bryan get his hands on this car and tune it. lol.
Old Jun 6, 2012 | 05:15 PM
  #43
100% METH's Avatar
Old Jun 7, 2012 | 12:04 PM
  #44
ebristol's Avatar
Originally Posted by 100% METH
He is saying you suck as as tuner. jk!
Old Jun 7, 2012 | 12:16 PM
  #45
100% METH's Avatar
That's for sure !
Old Jun 10, 2012 | 04:11 PM
  #46
freakta's Avatar
wow, looks fun. cant wait to do that to my car
Old Jun 11, 2012 | 11:16 PM
  #47
rcorona8's Avatar
update...bs are out....finally. question, the bushing for the bs delete kit goes by itself in the back of the motor?
Old Jun 13, 2012 | 11:44 PM
  #48
rcorona8's Avatar
update........bs delete kit has been install....chain drive and assesories have been install together with timing valve cover...my only concern is the I install the original harmonic balancer with the original bolt...books says to use a new bolt....
Old Jun 15, 2012 | 11:59 AM
  #49
freakta's Avatar
i would get a new bolt...
Old Jun 15, 2012 | 12:41 PM
  #50
subd for results. sounds like the build i want ( only on a tvs )
