LSJ Mini Build ;)
Old Jul 20, 2012 | 03:43 PM
  #126
rcorona8's Avatar
Process of elimination.....car cranks cranks cranks but wont turn on......
Camshaft sensor?
Crankshaft sensor?
Fuel pump?
Injectors?
Spark plugs?
Clutch pedal?
Crank relay/fuse?
Alternator/starter?
Anything else? Anyone?
Old Jul 20, 2012 | 06:41 PM
  #127
ItalianJoe1's Avatar
CKP = Crank position sensor.
If it's not plugged in or messed up, the PCM will not see the engine turning and won't give spark. I had to replace mine once, they're fairly cheap and can be changed without removing anything else, i'd say give it a shot.
Old Jul 21, 2012 | 12:04 PM
  #128
rcorona8's Avatar
Im doing this today. Did u had to case relearn you car?
Old Jul 21, 2012 | 02:34 PM
  #129
dtabbs's Avatar
Old Jul 21, 2012 | 09:09 PM
  #130
rcorona8's Avatar
Help guys, replace crank sensor and still wont fire up...... I have a mechanic here and we tested compression and is good......he says we dont have.spark.......help
Old Jul 21, 2012 | 09:31 PM
  #131
rcorona8's Avatar
We could not figure out. Sometime next week im replacing cam sensor......
Old Jul 21, 2012 | 09:38 PM
  #132
Sunburst_SS's Avatar
well, if the crank sensor is good......and you have no spark. Check your ground for the coils.......it is the ground wire that attaches on the front of the transmission.
also, check the INJ fuse in your fuse block....should be a 10 amp fuse.
Old Jul 21, 2012 | 11:42 PM
  #133
rcorona8's Avatar
The ground wire on thr transmission, do I get to it from the bottom of transmission?
Can you give me lil more info on how to locate such fuse on block?
Thanks alot man for ur help.
Old Jul 22, 2012 | 01:38 AM
  #134
rcorona8's Avatar
Never mind, found inj fuse on block and its good. Ill check grounding tomo.
Old Jul 24, 2012 | 12:43 AM
  #135
rcorona8's Avatar
I found about 4 grounds. One on driver head light, one on driver firewall, one below head light and one on transmission.......oh and the one the goes from motor to valve.cover. Still wont fire up :%
Old Jul 24, 2012 | 12:45 AM
  #136
rcorona8's Avatar
And I have zero codes.....I even have an extra obd2 reader....and no codes
Old Aug 1, 2012 | 09:57 PM
  #137
rcorona8's Avatar
So I worked on my car today and replaced the cam sensor and still wont fire up......im really pissed off now........
Old Aug 2, 2012 | 01:53 AM
  #138
InfraRedline's Avatar
I wish I could chime in with some direction to point you in, but all I really have is hang in there man.
Old Aug 2, 2012 | 12:50 PM
  #139
rcorona8's Avatar
Lol. Thanks. This sat. Im doing my timing again. See what happens.
Old Aug 2, 2012 | 09:34 PM
  #140
did you do all your basic checks.....fuel pressure? Spark? all that........
Old Aug 3, 2012 | 11:38 AM
  #141
rcorona8's Avatar
Yes! I check fuel pressure, fuses, grounds, replaced sensors. I just dont think im getting any spark, I check wiring and looks good.
If all the above its good and if timing is off, wouldnt car still fire up at?
Old Aug 3, 2012 | 07:57 PM
  #142
well, you can get a spark tester cheap at the store and check to see if you have spark.
The car will start and run even if the timing is a little off......now if it is way out, then probably not.
Old Aug 3, 2012 | 08:08 PM
  #143
carstedt's Avatar
u make sure the sensor on the back of the firewall is plugged in...mine was unplugged after my build and i had the same issue..plugged it in and bam
Old Aug 3, 2012 | 10:56 PM
  #144
rcorona8's Avatar
Can you please give me more details where it is?
Old Aug 4, 2012 | 05:08 PM
  #145
euthanasia's Avatar
I think he is talking about the cam sensor.
Old Aug 7, 2012 | 12:36 AM
  #146
rcorona8's Avatar
Still no luck.
Old Aug 7, 2012 | 12:54 AM
  #147
100% METH's Avatar
all your sensors plugged in?
still on stock tb?
dang rudy this sucks... it's like your chasing a ghost
Old Aug 7, 2012 | 10:59 AM
  #148
Don't know if this has been covered, but did you remove/loosen the fuse box at all? I've seen problems happen from the connectors coming slightly unseated. Try removing and re-installing the big connectors under the fuse box, then go over all the fuses and relays and make sure they are pushed down properly.
Old Aug 8, 2012 | 05:38 PM
  #149
rcorona8's Avatar
Im actually going home early today to work more on my car and im trying this today.
Do u guys think the ignition control module is.bad?
Old Oct 18, 2012 | 04:56 PM
  #150
rcorona8's Avatar
update. cat is ready. picking it up today
