Meth/Cooling mods
Old Jul 16, 2011 | 10:22 PM
shawn672's Avatar
Meth/Cooling mods
Hey guys!
I was hoping someone could give me some more information on how Methanol injection works. I've read Devil's Own website and some others, but I've never dealt with methanol before.
I'm also looking for any ideas on cooling mods, I remember this being a huge issue back in the SS/SC days but I never took my SS past stage2. Looking to currently reduce the IAT's and overall heat really because my platform has a terrible IC and gets crazy heatsoak extremely quickly, especially during days above 80 degrees.
Any help is appreciated, thanks guys
Old Jul 17, 2011 | 08:14 PM
shawn672's Avatar
No one? Hmm this used to be a huge thing in the past...
Old Jul 17, 2011 | 08:23 PM
06_SIC_SS's Avatar
methanol will help temps up in boost while it is spraying but not just cruising around on a hot day.. ull see ur biggest gains in power with methanol injection after tuning for it and either raising boost levels... or timing.. or both depending on ur set up and what you want.
it can be the single best modification you do to a car when done properly and researched correctly..
many ask how long a tank will last. for example a gallon tank.. and the answer is that it varies depending on different variables including how u drive.. if ur always in boost and having the injection constantly spraying.. it wont last as long.. say a week for this case.. another variable being nozzle size.. nozzles range from 3 to 15 gallon per hour.. for stage 2.. 3 GPH is plenty and would be a nice compliment to the 15ish pounds of boost ur running ..
as for engine/block damage.. mixing the methanol with distilled water will be "safer" than running pure methanol but it will not cause any damage to the motor.. its sprayed as a mist that mixes with the air charge.. cooling temps and then combusting within the cylinders.
adding methanol injection wirhout tuning for it will show virtually no effects.. some lower temps.. but thats it. no power gains.
hope this helps
Old Jul 17, 2011 | 08:49 PM
shawn672's Avatar
Well where I'm at right now, my turbo is pretty much maxed out at peak flow. I'm purely looking to keep IAT's and overall heat down, otherwise I'm getting terribad heatsoak almost immediately
Besides a more effecient IC, which is still in the works. I've also considered n2o or cry02 IC sprayer. Any thoughts?
Old Jul 17, 2011 | 08:53 PM
06_SIC_SS's Avatar
sprayers on the IC will again help temps.. personally id spray n2o cuz anything that isnt used up in cooling will be used as horsepower. while co2 will only cool
Old Jul 25, 2011 | 01:28 PM
jonnymerk's Avatar
are you driving a turbo Cruze or lsj?
Old Jul 25, 2011 | 05:50 PM
IonNinja's Avatar
How do you decide which size nozzle to run is always what I've been unclear on
Old Jul 25, 2011 | 05:56 PM
shawn672's Avatar
turbo cruze.
sold the lsj years ago :/
the cruze community isn't at the same place the cobalt community is (5+ years of modding), so i figured maybe you guys would have a better idea
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
