More Torque than HP mods
Old Apr 11, 2008 | 11:09 AM
r0k0's Avatar
What mods could give me more Torque than HP...?
right now i'm pulling 205WHP and 182WTQ.. i wanna put that higher before i hit my Stage 4..
Thanks
Old Apr 11, 2008 | 11:15 AM
Kritter's Avatar
I may be WAAAAYYYYYY wrong on this, I'm not tech by any means, but I would guess that you can't really get more torque than HP, when you consider the fact our enine is small, and HP is what generates torque...You have to have the HP to make the torque, so to me logic would suggest that the torque(At least in our cars) cannot surpass the HP.
Again, I may be wrong, but just thought I'd put it out there
Rodimus_Prime's Avatar
I really wouldnt worry about it, torque is never going to be in short supply with this car
even stock 1st gear is basically useless, when you start modding 2nd will be as well
Old Apr 11, 2008 | 11:36 AM
r0k0's Avatar
just asking because the 2.2 always gets more torque than hp even when they modify :P
Old Apr 11, 2008 | 11:37 AM
lsjwannabe's Avatar
Your tq is fine, pulley down if you want more tq
Old Apr 11, 2008 | 11:38 AM
Tomtwtwtw's Avatar
Yeah, put a really small pulley on with no cooling mods, and watch your torque soar, while your hp will...well, your torque will soar.
Old Apr 11, 2008 | 11:41 AM
silentd's Avatar
this is extremely wrong. Hp is generated by Torque through a math problem.
"Horsepower is a unit of power. It can be defined in many ways. In its basic sense, it's defined as work done in a straight line as described above under "Power". But when the work is not done in a straight line, it must be defined in a different way: torque.
Horsepower = (Torque X RPM) / 5252
Now although horsepower in this instance is defined by rotational forces, it is no different than straight-line horsepower. For instance, if you wrapped a rope around the circle and allowed the torque to pull the rope, the force on the rope would now be exactly as defined above."
r0k0's Avatar
well i'm planning on the Dual Pass end plate.. then my TB Swap.. after maybe of month of testing that out with the stock puley... my 2.6" is going on.. i already have it here so i just need the install with my meth injection kit with the dual pass..
Old Apr 11, 2008 | 03:03 PM
-Jayson-'s Avatar
ty, i sometimes forget that there are a few people on this site that actually know what they are talking about. Instead of all the nameless idiots spewing out crap they heard in F&F.
With torque the power curve is more important than the peak number. And usually the best way for more torque is more air or to get the air moving faster through the engine.
Old Apr 11, 2008 | 03:14 PM
roadrage06's Avatar
HA... BAM... i was just about to post this but wanted to make sure no one else did. I just read this in MotorTrend. /beat me to it.
It is IMPOSSIBLE to have more torque than hp.............so, to the Original Poster....................good luck with that.
Old Apr 11, 2008 | 03:21 PM
Harmigula's Avatar
It's impossible to have more torque and hp? I think LT1s would beg to differ... or l98s... or most gm v8s
blkss07's Avatar
just an FYI the F35 trans is rated at 298 FT pounds of torque. or **** if you got the loot get your gears cryoed and go for those high numbers. Also I think the 2.0 L cobalt that hahn did made 420 hp and only 299 torque
Old Apr 11, 2008 | 03:23 PM
Tomtwtwtw's Avatar
Um, if your torque peaks before 5252 rpm, then it's entirely possible to have more torque than horsepower. Perfect example - my old Grand Am. 155hp and 185 tq. Why? Because it peaked at like 4000 rpm and fell flat on its face.
Old Apr 11, 2008 | 03:24 PM
D4u2s0t's Avatar
base model cobalt - 145hp, 155 tq
motortrend is wrong, or you read it incorrectly. there's loads of cars that can be named that make more torque than hp
Old Apr 11, 2008 | 03:28 PM
travisworm's Avatar
Most Diesel engines make more torque than horsepower.
Old Apr 11, 2008 | 03:29 PM
blissmaster13's Avatar
Ok as far as having more torque than horsepower......DIESEL TRUCKS!!!! Enough Said.
Edit: Damn just one post too late.
Old Apr 11, 2008 | 03:35 PM
roadrage06's Avatar
read post #13, he explains it pretty good. yeah I read it wrong........sorta. It's not possible calculating torque from hP anyway... physically is another story. Using this formula you will never get a higher TQ.
MY BAD!
Old Apr 11, 2008 | 03:37 PM
esfkotaro's Avatar
um...yes you can.
unless you are really bad at math.
Old Apr 11, 2008 | 03:39 PM
roadrage06's Avatar
this is where you're going wrong. you don't calculate torque from horsepower, you calculate horsepower from torque
well ****... i'm done...lol. the boss needs to let me go early, I know the brain is fried when I just start talking, thinking I just might redeem myself.
Old Apr 11, 2008 | 03:42 PM
D4u2s0t's Avatar
yea, i'm home from work so i'm refreshed
Old Apr 11, 2008 | 03:44 PM
roadrage06's Avatar
i got 45 minutes..lol. Then I get to go out to my car that I'm positive makes less torque than horsepower...lol.
Old Apr 11, 2008 | 04:00 PM
celicacobalt's Avatar
check my tq out on my sig
Old Apr 11, 2008 | 04:05 PM
roadrage06's Avatar
yes, i know.... no more rubbing it in...lol. Now i'm down to 20 minutes and I can go to my car that makes less TQ than HP and my world will make sense once more
Old Apr 11, 2008 | 04:55 PM
silentd's Avatar
lol ya you can make more tq then hp or vis-versa, its all based on that equation though. it depends on where you make the power, most v8s dont rev to 7-8k, thats why they have more tq
Old Apr 11, 2008 | 05:10 PM
TVS_SS's Avatar
Torque and HP are TOTALY DIFFERENT UNITS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You must first understand what torque and Hp are before you say you want more of one vs the other.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
