need help figuring on injectors
Old Mar 23, 2008 | 11:25 PM
mike25's Avatar
injectors and fuel pump
well...im getting close to being ready to buy injectors...now im wondering what will be a good rate to go with....i was suggested to go with 42lb/hr...but im not sure if theyl hold up to my goals(12psi...hoping for around 300)...also, would anyone happen to know a place where i can find the specs on the stock fuel pump for the 2.4's? im going to do some research but it would be nice to know before hand
Old Mar 24, 2008 | 11:34 AM
mike25's Avatar
so nobody wants to chime in?
Old Mar 24, 2008 | 12:11 PM
light'bolt's Avatar
Here's some info....
http://www.rceng.com/technical.aspx
Old Mar 24, 2008 | 12:14 PM
fiftyandsoco's Avatar
i'm not sure man. hopefully the link above helps out. i'm only familiar with the ss/sc specs.
Old Mar 24, 2008 | 12:16 PM
mike25's Avatar
thanks...i checked that but im not sure what the fuel rail pressure on our cars is....anyone know? i est. for 60 which came out to be about 48lb/hr injectors
Old Mar 24, 2008 | 12:20 PM
not sure. try sending a PM to wickedSS2005. His name's Tom, and he knows more about these cars than just about anybody. he might know, or be able to tell you who does
Old Mar 24, 2008 | 12:22 PM
mike25's Avatar
ok ill hit him up...i wouldnt think it should be too much higher than that should it?
Old Mar 24, 2008 | 01:36 PM
chevytech007's Avatar
58 psi rail pressure! Also are you going turbo? and are your goals 300 whp or engine power?
Old Mar 24, 2008 | 01:39 PM
mike25's Avatar
i would like to see the engine make 300...but 300whp would be ideal
would anyone happen to know what fuel pump the 2.4 is using? i searched last night on google and i didnt find and actual specs...just different aspects of the pump
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
