OFFICAL 06blackg85ss Build (some new toys arrived this week)
A few weeks hopefully... just waiting on my ARP stuff and head gasket to finally get in. But I"ll be testing on the stock motor for now since my head was finally sent out to be cnc ported, custom cams, oversized valves, Ti retainers, new valve springs.... It's all out being worked, just waiting for it to come back.
Also gonna probably swap out the compressor housing to a t-60 for now just so I can fit it somewhere.
9.5:1 for this build, waiting for someone to release a 8,5:1 or 8.0:1 compression. Might hold off on motor assembly til then. Gotta see what comes up. Want to do this once the right way and have a motor that lasts. But I will be building up my stock one also as a spare just in case I have problems
Damn that is going to be a crazy setup. Im just wondering if you could tell me where you are sending your heads out and how much it is for you because I am actually considering JBP stage 3 heads so I am not sure if there is another option for me thanks.
it's a Turbonetics custom T-76 Ceramic ball bearing, big shaft, Q-trim turbo. A little big, but the price was rediculous, so I'll probably just swap housings around til I come up with a good combo. This turbo cost my Friend over $2500 new. Not gonna say what I paid for it lol. butit only had 3 dyno pulls on it. thing is as close to brand new as you can get
head is being done by the guys that did jason whitfields cobalt... close to the same spec and setup too...
Last edited by 06blackg85ss; May 12, 2007 at 01:21 PM. Reason: Automerged Doublepost
On a total side note....
Did you know that if you take those plastic vacu-formed accessory displays OUT of those Dremel XPR accessory cases that there are dividers you can use to hold a lot more stuff in those little accessory cases?
LSX RWD S/C conversion
good **** man. did they create a pn for them? and how much they run you? (you can pm that if you want) I might be placing an order monday then.
Anyone interested in a set of 9.5:1 diamond pistons uncoated... lol
savannah monitor... lol
and don't worry about spool time. I have a few different compressor and exhaust housings coming in next week so I can tailor it to my motor... plus... who the **** wants peak torque off the line anyway. I have a hard enough time hooking up with the setup I have now... and I have every traction mod available on my car at the moment........ and slicks
******* traitor!!!
