Official Gen III Block Thread
Old Apr 27, 2014 | 11:37 PM
Bluelightning's Avatar
Got Bewst?
Originally Posted by Omiotek
i thought you bought an ldk? ldk is still considered a gen 2 if im not mistaken since its essentially an lnf. either way im pretty sure the gen 3 some blocks have oil coolers for the 2.0 regardless. its like the older le5s some have them some dont.
none the less as ive seen on the forums you cant just drill and tap the holes either for the exsisting oil cooler. if you did that there wouldnt be any pressure. gm has a sleeve in there ive had to machine before to make the non oil cooled block adapt for a oil cooler.
LDK is the Gen 3 block. The 2.4 block just doesn't have an oil cooler.
ZZPerformance - Gen 3 LSJ Short Block #ZZ-LSJSB
Old Apr 28, 2014 | 08:04 AM
Omiotek's Avatar
gotcha. yeah a few guys here are considering it a gen 2. honestly i would just get the 2.0....... looks to have a little more to it then the 2.4
Old Apr 28, 2014 | 12:57 PM
Got Bewst?
Yaaaaa it's nothing like the Gen 2 haha. Looks to have a little more to it?
Old Apr 28, 2014 | 01:25 PM
slitterell's Avatar
So what did ZZP send you? Do you have pictures?
Old Apr 28, 2014 | 02:15 PM
Got Bewst?
The only thing ZZP changes to make the LDK work with the LSJ is they modify the reluctor wheel.
The motor:
The oil cooler:
Old Apr 28, 2014 | 03:19 PM
slitterell's Avatar
same issue as this.
https://www.cobaltss.net/forums/2-0l...cation-307703/
Old Apr 28, 2014 | 03:23 PM
slitterell's Avatar
JapEatr (VW) is supposed to send me pictures. He set up TaintedRed's (David's) setup so I will see. and post up from there.
Old Apr 28, 2014 | 04:54 PM
Got Bewst?
That's only a 2.4 block issue. Not 2.0.
Old Apr 28, 2014 | 05:27 PM
slitterell's Avatar
Interesting. 2.0 block create a 2.0 with lsj crank?
Old Apr 28, 2014 | 06:41 PM
Got Bewst?
The entire set up is a 2.0 LDK engine. ZZP just takes the crank out and modifies the reluctor wheel so it will work with the LSJ. The motor is a direct drop in for an SS/TC. That pic I posted of the oil cooler ZZP sent with the motor. It was a direct bolt on. I just had to run a custom length coolant hose because as you can see in the pic one fitting on the cooler faces the wrong way.
Old Apr 28, 2014 | 08:31 PM
  #36
slitterell's Avatar
Makes sense.
Old Apr 28, 2014 | 08:36 PM
  #37
BlkWdoSS's Avatar
The oil cooler:
That is an HHR SS/TC oil cooler...
Old Apr 28, 2014 | 08:39 PM
  #38
Got Bewst?
There ya go lol. I just know ZZP sent it with my motor because the lsj one doesn't fit at all.
Old Apr 29, 2014 | 03:37 AM
  #39
slitterell's Avatar
The motor:
Isn't these direct injection pistons? They didn't even swap over pistons?
Old Apr 29, 2014 | 06:31 AM
  #40
C_A_D88's Avatar
Gen 3 2.4 here
Subbing for later
Old Apr 29, 2014 | 08:30 AM
  #41
Got Bewst?
Yes they are. When I first talked to zzp about this motor they told me the pistons were swapped. I got the motor and was like wtf. Well I guess they thought I was talking about their forged Gen 3 motor for some reason. You can run DI pistons in an lsj it just isn't as optimum. At the time back in October they had already done over 20 of these motor swaps without issue. Going from the lsj to the Gen 3 with DI pistons they said it made no difference in the tune. I'm still just breaking in my motor but so far so good.
Old Apr 29, 2014 | 01:44 PM
  #42
slitterell's Avatar
Yes they are. When I first talked to zzp about this motor they told me the pistons were swapped. I got the motor and was like wtf. Well I guess they thought I was talking about their forged Gen 3 motor for some reason. You can run DI pistons in an lsj it just isn't as optimum. At the time back in October they had already done over 20 of these motor swaps without issue. Going from the lsj to the Gen 3 with DI pistons they said it made no tune. I'm still just breaking in my motor but so far so good.
I hear you. I was just making sure you knew. what kept you from buying Pistons to install?
How are you liking the Gen III? Still
Old Apr 29, 2014 | 03:40 PM
  #43
Got Bewst?
Well I really didn't want to tear a motor that was just apart back apart again. Second was money. I went through 3 motors in a year. Had some bad luck. And the Gen 3 motor in it's stock form is good for over 500whp. If I want more than that I'm going to buy something with 4 more cylinders. Granted a forged piston is stronger and less likely to fail, this motor should be able to take what I'm going to throw at it with ease.
I've only been ripping around on it with low boost. I'm itching to turn the dial and see what this S252ET can do. But so far no complaints with it at all.
Old Apr 29, 2014 | 05:02 PM
  #44
slitterell's Avatar
I can't wait to get mine in but I have financial obstacles in my way. That and this oil cooler issue
Old Apr 29, 2014 | 05:49 PM
  #45
mrbelvedere's Avatar
if it is not tapped for a cooler I would not worry about it
Old Apr 29, 2014 | 06:56 PM
  #46
noorj's Avatar
I agree, I don't think an oil cooler is really needed unless it's a track car
Old Apr 29, 2014 | 08:18 PM
  #47
BlkWdoSS's Avatar
yea, I did a clutch swap on a friends HHR and seen theirs is smaller than ours, I was like WTF! jelly! I hate how big our factory one is.
Old Apr 29, 2014 | 09:45 PM
  #48
slitterell's Avatar
Why the opinion change?
Old Apr 29, 2014 | 11:40 PM
  #49
Omiotek's Avatar
I don't think he has an opinion change. hes just saying if theres no ports for an oil cooler its not worth the hassle to add one. the lnf/ldk runs warm so I recommend them just for the hell of it but its not 100% neccisary. I track my car so its definitely getting an air to air setup with aux fan whenever the motor decides to let loose.
Old Apr 30, 2014 | 04:55 AM
  #50
slitterell's Avatar
I had previously talked to him about this haha
