Procharged SS/SC new video
Old May 27, 2008 | 11:49 AM
  #326
Speed Mafia's Avatar
Originally Posted by elecblue06
WHAT NOOOOOO WE WANTS OUR PRECEIOUS NOWWWWWWWWW
which guy he raced? the mustang?
yep stang...
our preceius.... ha ha ha! nice!
Old May 27, 2008 | 11:53 AM
  #327
tombomb's Avatar
Subscribed!
Old May 27, 2008 | 01:45 PM
  #328
from what i understand the 2.4L w the procharger on a low boost number is making great power but again a dyno will show the real number.
Old May 27, 2008 | 06:15 PM
  #329
rickyw's Avatar
speed we are suppose to do a con call with chevytech do you know when?
Old May 27, 2008 | 09:01 PM
  #330
sure dont...do you want me to set it up on our bridge?
Old May 28, 2008 | 01:40 PM
  #331
GermanKat's Avatar
Matt,that your posting up vids is all nice and dandy,but I have a strong feeling that things are gonna turn ugly if the balt isn't done soon.I mean honestly,you effed up pretty well with those piston rings....
In the meantime you might wanna think about how you're gonna get the car to SC if it isn't done by the 15th.we're not gonna be stuck without it for 3 years or more because of you
Old May 28, 2008 | 07:34 PM
  #332
chevytech007's Avatar
Sorry
This is somthing that could get done in a pm but let me get you the low down really quick!
The specs for the pistons where not with the pistons so I measured as close as possible and order a set of oil rings just a shy to large. Also I have my car in the shop right now starting to fab up the turbo and thats another reason why I dont have the videos ready. The engine will be done before the 15th as I have everthing else done.
Also you can call me anytime day or night to check on it i dont mind and I understand your time constrants!
Old May 28, 2008 | 09:25 PM
  #333
ColeJJones's Avatar
Bannned
huh? i wanted to do my build through you dude. am i going to get fucked over?
Old May 28, 2008 | 09:52 PM
  #334
Nobodys getting f*** here! They are just on a major deadline and these engines are not like a honda. The parts are harder to get or are custom ordered! Anything like this is very time consuming and I do my best to get this stuff done as soon as I have the parts!
Im more then likly am not going to build to many more cobalts because of the parts issues I run into. I have built hondas and mitsubishi with all the parts in a weeks time but the ecotec seems to be the hardest motor to get parts for and even harder to get them in a resonable amount of time.
Old May 28, 2008 | 10:40 PM
  #335
ColeJJones's Avatar
Bannned
so i have to order all the parts first and then wait to go to you for the build??
Old May 28, 2008 | 10:45 PM
  #336
jimbos'ss's Avatar
there is only a couple of things that are hard to get, the pistons take forever to get if you go with a custom bore. the pistons rings will have to be custom made if you go with a custom bore as well. everything else is pretty much off the shelf for these motors. if you order from diamond pistons and have them make you a custom bore expect 5-7 weeks at least, and thats if they get it right the first time.............so note to you cole go with a standard bore diameter and comp ratio.
Old May 28, 2008 | 11:03 PM
  #337
Raven SS's Avatar
or go with a piston company that is more responsible to not "lose" ur build sheet behind a deck on the floor and find it 4 weeks after the order
Old May 28, 2008 | 11:25 PM
  #338
jimbos'ss's Avatar
yah i wonder if wiseco is any more reliable, or maybe mahle. diamond is slow as hell.
Old May 28, 2008 | 11:29 PM
  #339
Raven SS's Avatar
i would never buy mahle...they make our stock pistons
Old May 28, 2008 | 11:36 PM
  #340
jimbos'ss's Avatar
they also make stock srt-4 pistons................
Old May 29, 2008 | 12:13 AM
  #341
ColeJJones's Avatar
Bannned
but i will be able to push more hp with a bored out sleeve.
Old May 29, 2008 | 12:33 AM
  #342
jimbos'ss's Avatar
well than you risk having major delays in your build, for only 4 more cc's of displacement.
Old May 29, 2008 | 12:48 AM
  #343
ColeJJones's Avatar
Bannned
what is your build worth in hp? angelo is trying to get 400. what will yours be rated at? what will a stock bore and comp yield??
Old May 29, 2008 | 02:26 AM
  #344
jimbos'ss's Avatar
i'm looking for about the same, my build will be limited by my cams a bit, but i can always upgrade from here, ie larger compressor turbo, cams, equal length turbo manifold, and a few other things. thats the great thing about turbo setups you can always upgrade.
Old May 29, 2008 | 02:27 AM
  #345
ColeJJones's Avatar
Bannned
i wanna do the procharge... the P-1SC is what i want...
Old May 29, 2008 | 02:33 AM
  #346
jimbos'ss's Avatar
it's a nice setup, but not for me. it's much easier to setup than a turbo setup like mine.
Old May 29, 2008 | 02:38 AM
  #347
ColeJJones's Avatar
Bannned
i hope so. Angelo was saying that they might have to cut some of the front bumper away to make it fit
Old May 29, 2008 | 02:41 AM
  #348
jimbos'ss's Avatar
yah it does require a bit of modification, the compressor housing on those things is huge. it will sit right above and a bit forward of your motor mount.
Old May 29, 2008 | 02:53 AM
  #349
ColeJJones's Avatar
Bannned
so i should start a poll.
procharger vs turbo vs supercharger....
what are the main dis/adv of the turbo to pro?
does the setup use the s/c mani?
Last edited by ColeJJones; May 29, 2008 at 02:53 AM. Reason: Automerged Doublepost
Old May 29, 2008 | 10:37 AM
  #350
jimbos'ss's Avatar
yes it can use the sc intake mani, but you would be better off switching to a hahn or saab or a 2.4l manifold. as far as main advantages disadvantages of each, that a long discussion and open to quite a bit of debate.
