SCcobaltSS's Engine Build
Old May 7, 2010 | 01:59 PM
  #176
BlackBaltSw's Avatar
Originally Posted by SCcobaltSS
Well I re timed the car yesterday. It was off. I did it without pulling the cover. Re positioned the cam sensor and started her up. After two clicks of the starter she fired. Idled WAY better than before but it still has a jumpy idle (ranges from 1000-1300 RPM) I am going to replace all the vacuum lines and re tune the timing for the cams.
I can press on the gas slightly and get the idle up to 1200 and it stays but once I take my foot off it'll jump again. I hope its still not one tooth off. I dont want to pull the cover.
No Codes Either
Congrats dude, hopefully the timing is perfect.
Old May 7, 2010 | 02:00 PM
  #177
ei3dag3's Avatar
subd
Old May 7, 2010 | 02:06 PM
  #178
SCcobaltSS's Avatar
There are no codes that I saw last night. So that leads me to think that the cams are timed since I am not getting a cam/crank correlation code. Anyone else think that? Or could it still be off and no throw the code?
Old May 7, 2010 | 03:20 PM
  #179
Im pretty sure it would throw the code. When i timed my old 2.2 i got a code almost instantly for cam correlation. It was off one tooth.
Old May 7, 2010 | 04:24 PM
  #180
SCcobaltSS's Avatar
That is what I thought, that is what happened the first time. I let it run last night for about 30 seconds and nothing. Now I just have to change vac lines button up the random stuff not connected and tune it. Then I get to drive it. I cant wait. Its been too long.
Old May 7, 2010 | 04:54 PM
  #181
importkiller's Avatar
Way back in 06 or 07 a guy I knew with an LSJ had it running like **** no cell just would not run well. It turned out that he was 1 or 2 links off on his camgears because he put new cams in. I sugested it to him at first and he swore that it was not the case a month later he told me I was right.
Old May 7, 2010 | 05:06 PM
  #182
SCcobaltSS's Avatar
Well I guess we will see. I didnt give it eenough time to go into closed loop or run for that matter. I am going to see if I can get it to work. If not then I will time it again. This time with the cover off.
Old May 7, 2010 | 06:41 PM
  #183
ItalianJoe1's Avatar
The intake cam could still be off, there's no sensor on that one. Most likely it's just tuning though for idle surge, or a vac leak as you mentioned.
Old May 7, 2010 | 06:43 PM
  #184
SCcobaltSS's Avatar
Yah. I will figure it out. Timing should be spot on but who knows! lol
Is the idle control in the TB? Will that throw a code if it is going bad?
Old May 7, 2010 | 07:05 PM
  #185
The TB does IAC control, but a lot of it is timing and fuel injector controlled as well. If there's a MAF problem it will idle like crap.
Old May 7, 2010 | 08:22 PM
  #186
SCcobaltSS's Avatar
ok cool. Maf is not terrible. When it was jumpy like that it was only +2 on the MAF cells. I did up my timing at idle to see if that helps, but have not loaded the tune to see.
Update: Vacuum lines did not change the idle. Still jumpy. Ran it for about 4 minutes and no codes. The timing still seems off. It is running at -1 degree advance at idle. Vacuum was jumping from -8 to -10.
So far in the tune I corrected the MAF to now be at 0 and -1, change the idle timing which it doesnt seem to get there.. What else do I need to change? I am lost if it has to do with the cams.
Old May 10, 2010 | 11:45 PM
  #187
SCcobaltSS's Avatar
Well I drove the car around today. Idle was still a little jumpy. Clutch felt good. I need to fix a leak in the intercooler/heat exchanger piping cuz the IATs are very high. I need to tune this thing some more. I am going to change the injector tables to see if I can calm the idle a little. Other than that it runs good.
Old May 11, 2010 | 04:42 PM
  #188
Jrhdpaintball's Avatar
how are those cams? any vids?
Old May 12, 2010 | 03:41 PM
  #189
SCcobaltSS's Avatar
My idle is still hunting. Someone is saying richen the idle up but I am unsure how to do this. Any input? I tune but IDK where in the program adds fuel for idle. I see it in OL but not closed. Doesnt closed loop read off o2 signals?
My exhaust has a different sound when it is driving. Probably combo from mild port and the cams. Sounds pretty good. once I am able to WOT I will hear the exhaust more to better judge. I can go WOT once I know I fixed the leak in the intercooler/HE hoses.
Old May 12, 2010 | 11:03 PM
  #190
hungryhip-ccp's Avatar
richen/add to
the first two maf cells its a band aid i know of. but really i dont know what your cams are doing.
Old May 13, 2010 | 04:02 AM
  #191
SCcobaltSS's Avatar
I am going to change to a stock tb. Then try some more tuning. I had a lot of help tuning troubleshooting. Made it a good night. bet my neighbors hate me.lol Have it narrowed to a specific area in the tune. Trying to get the thing to idle like its supposed to is another story. It loves -5 degrees of timing.
Old May 13, 2010 | 01:25 PM
  #192
SCcobaltSS's Avatar
I drove the car to work today. The thing felt good, except the funny idle. The car wanted to get up and move! I am currently searching for a stock TB so I can test to see if its the LS4. I am going to do that when I get home. Then do some more cam tuning. Hope all goes well with the TB hunt.
Old May 13, 2010 | 01:46 PM
  #193
anytime my car ever saw -timing is when my timing was off. granted the idle timing will hunt between 0-10* but it never goes negative.
Old May 13, 2010 | 02:19 PM
  #194
SCcobaltSS's Avatar
Well I re timed it the other week. I cant see it being off but anything could happen with this car. lol. Last night we got it to run on 5-15 degrees but after a minute it started to sputter and was bogging at 500 rpm. Had to kill it.
So how far off was the timing? A tooth?
Old May 13, 2010 | 06:07 PM
  #195
victory_red_SS's Avatar
LSX RWD S/C conversion
A word of advice, don't be in a hurry to get on the throttle or to even see boost for the first 500 miles. A rebuilt engine is not the same as a factory built engine and the breakin period should be different as well. Following this procedure has been a good thing for my DD unlike the previous 2 rebuilt engines.
Old May 13, 2010 | 10:30 PM
  #196
yeah, 1 tooth on the crank. it was when i did a headgasket and didnt remove the side cover. the chain fell down far enough to move over one link but up top it looked fine. pulled the front cover and sure enough it was off.
Old May 14, 2010 | 11:36 AM
  #197
SCcobaltSS's Avatar
Well I put on a stock TB, took it off my friends cobalt ss, idk if its from the cams or what but we were playing around with the tune last night and got it to go from -5 to +10 thru the idle. It sounded sweet!
Now at the end of the tune we got it to run at a really good idle, sounded cammed, and then at 3 minutes the car starts to surge/hunting. Weird thing is the trims are pretty bad when its running right i am talking -5 to -15 . Then about a 30 seconds before the idle starts to get shitty the trims go from -3 to +3 and when the idle is shitty they stay there. It is very weird.
So if I give it a little rev of the engine it falls below idle then goes to the good idle for about 10-15 seconds. Then get shitty again.. Weird car. I think I am going to time it one more time.
Here is a video (just for sound) of the idle.
http://s128.photobucket.com/albums/p...ent=cammed.flv
Old May 14, 2010 | 01:46 PM
  #198
sounds great man, glad everything is working out
Old May 14, 2010 | 02:37 PM
  #199
SCcobaltSS's Avatar
Yah I have a little further to go. Its awesome to have some good help in areas that I was unfamiliar with. I really appreciate all the comments and help I have gotten thus far.
Old May 16, 2010 | 11:00 PM
  #200
UgliestTurtle's Avatar
Is the computer taking control before and after the car warms up? Are they trying to adjust the cams thinking is stock?
