Tuners input needed ASAP
LSX RWD S/C conversion
I finally have the daily driver back together and my_bd and myself havea couple of issues such as the s/c boost bypass valve keeps opening and closing at idle. Perplexing.
Also the MAF sensor reading seem to be way too low. Any thoughts on the cause for this?We are running in VE and it runs much better than in MAF. At 3,000 rpms the car sounds great, no mise-fires, no codes.
Thanks,
Rod
Thanks,
Rod
Latest issue with the DD
Originally Posted by Area47
if you want some fun things to play with. shut off the maf, or unplug it. stick it in speed density mode for a while till the motor is broken in. or you get a new maf.
While running in VE mode with the idle set to 1,000rpms, it idles quite well while in FTC 37 (evap closed?)
but
leans out severely as soon as it switches to FTC 17 (evap open?)
Any ideas??
Once the lower piece of the intake was switched around and the MAF was able to work properly the other issues corrected themselves.
We now have the job of tuning in the car and we are close to putting it on the road for a load test. Obviously the cams are adding another layer of complexity to tuning, especially when we already have to deal with the larger TB and the TVS.
my_bd and I have hooked up the wideband and Interceptor so I have some cleanup to do as well as throw on the tires and the hood.
Soon I will be back on the road in a SS
have i told you i love you? that and your "DD" will smoke the snot outta mine.
that and i think you'll have THE fastest non-sponsored Cobalt ever. unless you are?
The DD definitely sounds like it wants to chew up the road
Too bad I don't know enough about the tuning part *yet* because I have to wait a bit as my tuner (my_bd) has a day job
My project car is 95% funded by me and the wife. I have minor sponsors which don't amount to anything significant. Although (hopefully), I may be able to get sponsors after the fact to help with racing costs.
Yeah, after I pay off the project car. The problem with good credit is a higher limit.
Yes it is a '06 SS/SC with all the possible bolt ons as well as a cams/P&P'ed head, pistons and a few other stronger internal parts to support the TVS blower.
This the car we have been working on this past couple of weeks. The rwd project car is still a few months away from being done.
The reason I look forward to having the DD on the road if to take my mind off of the project car as to well have some fun driving. Right now I am driving a 6.0l '01 Silverado and it isn't fun.
DAM
Dam man what do you do for living.
Last edited by MarqueDo7BabyBalt; Sep 22, 2008 at 04:44 PM. Reason: Automerged Doublepost
btw tell andrew i need him to scan my car again see if its misfireing at idle any more since the dealer finally replaced the timing chain assembly noise has never happened again i wanna see how its doing and if when i put on the gas in 3rd gear if its dumping a crap of fuel to compensate for the unusual heat of the cat-converter lol maybe i can go when you and andrew are doing some stuff with the DD i'd love to see it
You too huh
Iceberg
Sep 29, 2015 12:33 PM
roth
Sep 26, 2015 12:16 PM
