--||The Official Headlight and Taillight Thread||--
The old headlight and tail light thread was going out of date, and all the pictures are missing, so it's time for a new one. If anybody has a problem with me using a picture of their car as an example let me know and I'll take it down.
First of all, all cobalt head lights fit all cobalts and g5s 1st generation projectors https://www.cobaltss.net/gallery/fil...ccbt05bb_5.jpg https://www.cobaltss.net/gallery/fil...lhpcob05tm.jpg These use H1 bulbs for both the high and low beams 2nd Generation Projectors https://www.cobaltss.net/gallery/fil...pcob05jmks.jpg https://www.cobaltss.net/gallery/fil...cbt05cb_ks.jpg These use H7 bulbs for the low beams and H1 bulbs for the high beams 3rd Generation Projectors https://www.cobaltss.net/gallery/fil...pcob05jmyd.jpg https://www.cobaltss.net/gallery/fil...cbt05cb_yd.jpg These use H1 bulbs for the high and low beams 4th Generation Projectors https://www.cobaltss.net/gallery/fil...4/pics_003.jpg https://www.cobaltss.net/gallery/fil...b05phbc_dp.jpg These use H7 bulbs for both the high and low beams. Blacked out stockers https://www.cobaltss.net/gallery/fil...7/0/5/8892.jpg Stock headlight bulbs are 9007 On the stock lights, the 05-06s have amber turn signal reflectors. On the 07+, they're chrome. Also, if you have an 05-06, your parking lights are your DRLs. If you have an 07+ your headlights are your DRLs. So if you put hids in an 07+, pull the DRL fuse to avoid problems. To repeat myself because some of you out there on .net don't read through all of this, if you have an 05-06 Cobalt, your parking lights are your Daytime Running Lights. If you have an 07-10, your low beams are your daytime running lights. The type of headlight you have does not matter If you get LED turn signal bulbs, a resistor such as these will be required. Switchback Leds are awesome too. They are white when driving, then switch to amber for the turn signals https://www.cobaltss.net/gallery/fil...5/100_1379.jpg https://www.cobaltss.net/gallery/fil...5/100_1380.jpg I got mine on 3bspec.com. They are two types of them. Type 1 has it set up so when you turn your turn signals on, they flash between white and amber. Type two turns off the white and just flashes amber, then turns the white back on when you shut off the turn signal. Here's two videos as examples Type 1 Type 2 Type 1 can be found on 3bspec.com here Type 2 can be found on v-leds.com here Both can be found on vleds but remember that 3bspec is one of our supporting vendors. You will need to buy these load resistors to keep them from hyperflashing. The best head lights possible though, are retrofits. These are OEM projectors that are fitted in from BMWs, Acuras, G35s, etc. Currently, we have 2 vendors that sell retrofits, Streetracinazian, and buyhids.com. Both sell complete retrofit sets, and buyhids also sells do it yourself kits. They both feature the Morimoto Mini H1 projector, which is a fantastic projector. This is definitely the way to go on a good lighting setup. If you are buying a retrofit kit, I HIGHLY recommend spending the extra money on the Morimoto HID kit, instead of the generic cheaper one. The Morimoto kit is designed to work with the Mini H1 projectors which both vendors use, and are of a far superior, nearly OEM quality. 95% of the issues with retrofits are due to either incorrect user installation, or not buying the Morimoto hid kit. Our fog lights use H11 Bulbs 2 door coupe led tails https://www.cobaltss.net/gallery/fil...ob05rledks.jpg https://www.cobaltss.net/gallery/fil...lack_large.jpg https://www.cobaltss.net/gallery/fil...rome_large.jpg These come in a variety of black/red/chrome mixes https://www.cobaltss.net/gallery/fil...3_54181302.gif These come in red too https://www.cobaltss.net/gallery/fil...052gled_tm.jpg 4 door sedan tails https://www.cobaltss.net/gallery/fil...ledt_351cb.jpg https://www.cobaltss.net/gallery/fil.../ledt_351c.jpg These come in a variety of black/red/chrome mixes https://www.cobaltss.net/gallery/fil...05tled4d_1.jpg ^^ These come in chrome too To help clear up confusion that often pops up around here, the sedan tail lights are not the same as the G5 coupe tail lights, and are not interchangeable. All of these lights can be found from various supporting members. eBay will be the cheapest place for all of these lights, but our vendors are the most reliable. The quality for these lights is the same no matter where you go, they all come from the same respective factory, as in all the 1st gens are made in the same spot, etc. Vendors such as: Modern Performance PFYC 3Bspec Cobalt-Addiction Turbo Tech Racing ZZP all sell at least some of these lights. If any other vendors sell them let me know and I'll add them to the list, these are just the ones I know off the top of my head. all of these lights can easily be found on ebay Here are some helpful how to's How to paint your headlights How to paint head lights with CLEAR corners (Missing pics) LED 3rd Brake light Method 1 Method 2 3rd brake light relocation retrofit How to Tint Your lights How to replace a burnt out halo How to wire halos 3rd Gen anti glare mod(pictures are missing, but hopefully you'll get the idea) How to swap to CCFL halos How to remove + tint Sedan tails How to make retrofit headlights "Ultimate High Beam Mod" How to remove your headlights "Skyline Tail light mod" How to change fog light bulbs How-To: Replace a Burnt Out Halo Electrical How-To: Replace a Burnt Out Halo - Cobalt SS Network Let me know if I missed something. Also, if anyone has a request for pics of certain lights on a certain color car, post it and I'll do my best to find one. If anyone has any questions feel free to post them! |
add something on trunk lid lights like:
https://www.cobaltss.net/forums/show...hlight=skyline A vendor needs to make these for us, would sell like hotcakes Also, vette lights, but we need a good step by step how to on this: https://www.cobaltss.net/forums/show...1&postcount=44 (also not legal unless you add 1 reverse light in the bumper grill or get a g5 bumper) |
Originally Posted by JonyyB
(Post 4667477)
https://www.cobaltss.net/forums/show...hlight=skyline A vendor needs to make these for us, would sell like hotcakes |
^^^ x2! Those plus
https://www.cobaltss.net/gallery/fil...052gled_tm.jpg these tails together tinted would sell like crazy! |
how bout retros?
I was kind of leaving those out since the possibilities with retros are endless, that's kind of why I put the how to in. I wanted to limit this to what can easily found and installed from vendors. Maybe I'll write a little about it though.
factory style w black housing http://209.200.64.237/images/auto/8892.jpg
Also, 05-06 headlights have the amber over the turn signals, 07+ Don’t |
Originally Posted by Tommyp2010
(Post 4667536)
https://www.cobaltss.net/forums/pict...&pictureid=674
Half-assed pic. I'll get a better one later. I have stock black housing lights with 6k HIDS |
I bought the smoked LED tails off ebay. They are GREAT! THe pictures on ebay of them they look dark red. They actually have a clear smoked look. LED's are BRIGHT! I got these from k2motor. I searched Cobalt smoked LED tail. The description underneath said it was a dark red lense, but they came like this.
http://carphotos.cardomain.com/ride_...0050_large.jpg http://carphotos.cardomain.com/ride_...0051_large.jpg http://carphotos.cardomain.com/ride_...0054_large.jpg Feel free to use my pictures anywhere!!! |
^i forget do LS and SS fit the same tail lights?
Yes.
Thanks Rissa =)
No problemo. :)
Originally Posted by 06C0BALT
(Post 4679620)
https://www.cobaltss.net/forums/pict...&pictureid=749
close up on the car. https://www.cobaltss.net/forums/pict...&pictureid=588 before they were installed. |
(Post 4680587)
What ridged portion are you talking about?
Rissa, I think tomg is talking about the inner bottom part of the headlight reflector. Like how mine are painted..
https://www.cobaltss.net/gallery/fil...1/sdc10865.jpg |
Originally Posted by 06G85
(Post 4681612)
https://www.cobaltss.net/gallery/fil...1/sdc10865.jpg If the ridged portion is un-painted it looks like so http://i80.photobucket.com/albums/j1...022_985811.jpg |
oh wow everyones headlights in this thread are black. what a surprise
you know what? BAM!!!! http://i139.photobucket.com/albums/q...8GT/cobalt.jpg http://i139.photobucket.com/albums/q...GT/yellow2.jpg http://i139.photobucket.com/albums/q...GT/yellow1.jpg |
(Post 4679785)
http://carphotos.cardomain.com/ride_...0050_large.jpg http://carphotos.cardomain.com/ride_...0051_large.jpg http://carphotos.cardomain.com/ride_...0054_large.jpg Feel free to use my pictures anywhere!!! May i submit my headlights for the retrofit category? http://i415.photobucket.com/albums/p...g?t=1265946344 http://i415.photobucket.com/albums/p...g?t=1265946368 |
retros by blownss06
e55's https://img708.imageshack.us/img708/2044/dscn2900.jpghttps://img230.imageshack.us/img230/1615/dscn2885e.jpg https://img693.imageshack.us/img693/1295/dscn2914.jpghttps://img41.imageshack.us/img41/4900/goodcolour.jpg https://img134.imageshack.us/img134/1120/dscn2916.jpghttps://img715.imageshack.us/img715/1212/dscn2944.jpghttps://img251.imageshack.us/img251/2627/dscn2932j.jpg they are brighter than photos represent i tried to upload a close up of them but i just got wicked glare... |
Awesome info in this thread.
