07 Corner Light
Yeah, it's a crappy deal for us. Even at night, if I turn my switch down to turn off the auto lights, nothing will turn off. The light sensor on the dash trumps all, unless you have the e-brake up. So if you don't want the DRLs on, just pull the fuse like I said above. I did this months ago and my car hasn't given me any error codes or junk like that and I lost nothing else by doing it so you're good to go.
The fuse is in the engine bay, at least on my car it was. There's a diagram in there that tells you which fuse does what, just locate the one that says DRL and pull it out. You won't have anymore DRLs, but every other exterior light on the car will still function like it's supposed to.
As for the nickname, it's just that, a nickname. I don't know who you're referring to regarding me working for them.
anyways.. my HID arent on.. only when the sensor come to a dark place.. but its all good.. i'll post some pics soon
Thanks guys for the help
Oh. Nah it isn't anything to do with the government. Blech. It's much simpler than that. Just one of the hull numbers from one of the Star Trek Ships I liked a lot way back when. Been using this for years on damn near everything I sign up for.
i thought they werent working but my ebrake was on.. now they flicker because they do into low power mode for the DRL.. and in the fuse pannel the only thing i see for DRL is the relay for all the lights.. DRL, Low Beam, High Beam, Fog Light, etc..
which one do i have to pull out.. and i need to know before 3h30 pm.. thats in 30 minutes lol.. before i go to work..
Thanks
Thanks
My fuse panel had one labeled DRL. If I remember right, it was a 10, and red. Took me a while to find it on the diagram so look carefully. Mine was around the middle. I also had to pull one of the huge fuses out of the way so I had enough room to grab onto the tiny little fuse to pull it out.
found it.. it was more near the top right next to the Fuel pump fuse...
so no more DRL
no to get my Corner light runing..!
is there a Way to just run Foglight in the Night...?
i wanna see how much my HID Fogs light up in the night..!
Thanks for the Help Everyone..
so no more DRL
importkiller
Sep 30, 2015 07:18 PM
z28addiction
Sep 28, 2015 12:03 AM
