1st gen projector LED's.. Blinking?? help!
Old Nov 13, 2008 | 10:58 PM
RedEcotecSS's Avatar
So I got my 1st gen projectors yesterday that I ordered from another member. One of the lights (passenger side) was wired up already. I wired up the driver's side. All halo's and LED's work. But the LED's on the passenger side like to blink really fast. Kinda like a strobing affect. But its not all the time. Its most of the time but every now and then when I turn the lights on they are solid. No blinking or anything. Then randomly, they'll begin blinking real fast... It's crazy. I've already replaced and checked all the connections.. Even swapped out the resistor and nothing seemed to work..
Any ideas???
Oh, and the cut-off on the 1st gen's are 100000% better than it is on the 2nd. I love it..
Thanks!
Old Nov 13, 2008 | 10:59 PM
beercan's Avatar
I had the same problem with mine man, rewired them like 3 times and still did the same ****. So i just cut the wires and pulled the leds out. Couldnt ever figure out what was wrong.
Old Nov 13, 2008 | 11:02 PM
Yeah, that's my last resort..
I don't wanna do that tho!!
glen229's Avatar
on the power wire you need to put a 680 ohm resistor into the line to compensate for the lack of current the LED's are drawing
MachiBLue's Avatar
that would happen with mine too..i pulled the leds, just have the halo's for now.
Old Nov 13, 2008 | 11:03 PM
glen229's Avatar
edit.. check the ohm size on the resistor your running
are you sure that'll do it? Power wire to the LEDs i am assuming? Do you know the color code for the 680 ohm resistor?
Old Nov 13, 2008 | 11:05 PM
glen229's Avatar
hmm color code i am not sure of but just go to like radioshack itll be 4 bucks for like 5 .. kinda expensive but you have then that day
I have a brown, green, brown, gold resistor on now..
That should be a 150 ohm. Looks like I need to up it a little.
Old Nov 13, 2008 | 11:06 PM
glen229's Avatar
yes definitly since those are 3 leds.... i think that the 680 ohm shouldd be sufice for all 3 but its a start and my math is shaky this late haha
Old Nov 13, 2008 | 11:08 PM
So it sounds like a resistor problem with the flashing and strobing of the 3 LED's? Even tho it doesn't do it 100% of the time? Does it about 90% of the time tho..
Old Nov 13, 2008 | 11:10 PM
glen229's Avatar
id say so.. its a cheap try if it doesnt fix it tho...but that ohmage doesnt sound right if it indeed is 150 .. a minimum of 680 per led would be the ideal situation
Old Nov 13, 2008 | 11:14 PM
alright. i wonder if radio shack has a resistor key or anything
Old Nov 13, 2008 | 11:15 PM
glen229's Avatar
good luck in there parts draws.... make sure to check the package of resistors becuase there never in the right tray
haha i used to be the stock boy for them like 3 years ago.. i just threw that **** in
Old Nov 13, 2008 | 11:18 PM
alright man thanks for all your help. that's definitely worth a try.
Old Nov 13, 2008 | 11:19 PM
glen229's Avatar
no problem at all... hope everything works out for you
ill post some pics my Amber leds are coming in this week and im putting those in having them act as my directional and my bulb will only be my park light.. something different i hope it looks good
Old Nov 13, 2008 | 11:22 PM
i have a red ss/sc and today (first day i've had them in) one of my buddies had two of those LED clusters that fit nicely into your turn signal where the amber bulbs go. His were red. I put them in to see how they'd look. They make the turn signal blink fast as ****. it looks cool, but it's illegal. well, so is strobing LED's... hope to have that fixed tho.. hah
chefhhr
Oct 26, 2015 10:36 PM
brandon04
Oct 21, 2015 07:04 AM
How to Guide
57
Oct 15, 2015 11:56 AM
roadrunner132
Sep 19, 2015 04:35 PM
