About to Paint The RIMS!! :D ..
Old Mar 16, 2011 | 06:54 PM
Achilles's Avatar
Just like ; CHEVRO_SS's !!
What will I need to get?
Old Mar 16, 2011 | 06:55 PM
Shibito's Avatar
sandpaper, paint, and clear coat.
What color is your car?
BPacak's Avatar
Vtec Rep
tape and paint haha
Old Mar 16, 2011 | 06:57 PM
MastaShaKe_88's Avatar
some duc tape, painters tape... a short rope.. some water... an anything else you think you might need to hang from his nuts..
Old Mar 16, 2011 | 06:59 PM
but no.. wat they said ^^^ an some painters tape (use the green one), an some playin cards to block off the rims frm the tires
BPacak's Avatar
Vtec Rep
lmao
Achilles's Avatar
Cars white.
What kind of paint and Sandpaper? I am painting the stock rims so I assume there is clear coat already on them?
Old Mar 16, 2011 | 07:00 PM
BPacak's Avatar
Vtec Rep
yeah but your about to paint over it lol
Old Mar 16, 2011 | 07:02 PM
Achilles's Avatar
I assume I have to use some sort of acid to take the clear coat off the rims?
Old Mar 16, 2011 | 07:03 PM
BPacak's Avatar
Vtec Rep
sandpaper. come on man haha.
Old Mar 16, 2011 | 07:05 PM
Shibito's Avatar
This is what the sandpaper is for.
You will also need some paper towels or a rag to wipe off the wheels after sanding them.
Also, please take the tires off and clean the wheels thoroughly before painting. That means clean the inside too, you will thank yourself later.
Old Mar 16, 2011 | 07:06 PM
BPacak's Avatar
Vtec Rep
here ya go
https://www.cobaltss.net/forums/how-...n-pics-114387/
Old Mar 16, 2011 | 07:10 PM
Cars white.
Black...and white.. no really.. lol any other variations are up to you.. (gloss blk, super white, sparkling white bla bla bla...) or you could jus go to Autozone an buy the duplicolor GM color matching colors...
Wet sand to get all the 'clear' off and all the finish off the rims first, then keep sanding till its all smooth, an then sand with a finer grit.
There's a How-to floatin around on here somewhere...
wipe them off with water/alcohol(not Jack Daniels)
Prime them first with..primer
sand w/ the fine grit after the prime...
block off what you're gonna paint first
spray... sand...spray..sand.. spray..sand.. 2 coats clear.. an then hit the strip club up...
then next day, tape off what you're not gonna paint again, and repeat said steps with other color.. including strip club
^^in that order^^
an enjoy
Old Mar 16, 2011 | 08:06 PM
Achilles's Avatar
Just bought 4 cans of Rust Check / Rust Paint Black and 2 white +2 Dupli Color - High Performance Wheel Coating and 2 grit sandpaper.
The paint says I don't need to prime, I just apply so I assume their is primer already in it.
I wish their was a video floating around! Would be much easier.
Old Mar 16, 2011 | 08:12 PM
all i can really say is... jus make sure your blk is done drying all the way before you decide to tape it off... or vice versa...
Dart_SI's Avatar
its easy, just sand it all over so you get rid of the clear coat. it should look really scratched up. then tape off whatever and start painting. make sure you give plenty of time to dry. id also pick up a can of clear coat to protect the paint when your done.
Old Mar 16, 2011 | 08:30 PM
StevoElSupremo's Avatar
Oh DAMN that white car looks GOOD!!!!!
Old Mar 16, 2011 | 10:03 PM
Achilles's Avatar
Tomorrow is the big day, I am getting excited =D
Old Mar 16, 2011 | 10:06 PM
07BoostedG5's Avatar
big tip, Take your time!!!!! and listen to the dry times on the can!
Old Mar 16, 2011 | 10:07 PM
murphxrockstar's Avatar
if you dont have an idea what you're doing, find someone that does. Im not trying to be mean, just it's real easy to mess up. I've painted mine twice already, and both have come out looking professional. (I just did mine today gold, I posted a thread). I spent about 5 hours, but yours will take way longer due to the fact that you're doing two colors. You have to let each color dry COMPLETELY before taping it off, or it will look shitty.
*Take the time to do it right.*
Old Mar 16, 2011 | 10:12 PM
DiabeticKripple's Avatar
i honestly would do this over 2 days, one day per color
Old Mar 16, 2011 | 10:15 PM
Agreed.
Old Mar 16, 2011 | 10:18 PM
^x3 that would be the best way to do this
Old Mar 16, 2011 | 10:19 PM
just to allow complete drying and adhesion before you tape. i painted my door bezels last night, after an hour drying, when i tried to install them, the paint let go and i had to redo it.
Old Mar 16, 2011 | 10:26 PM
When you're done painting, I'd remove the masking tape ASAP allowing the paint to bond though
