adjusting the projectors
Old Aug 26, 2006 | 11:46 PM
hardtocope's Avatar
how do you adjust the low beam on the ebay projectors? There is two screw on the bottom of the low beam. I screwed them so they are all the way in. But my low beams seems like there pointed at the ground to much. They can't really be adjusted while in the car.
Old Aug 26, 2006 | 11:47 PM
Dead Zen's Avatar
They are very adjustable in the car. u just need a 10mm and a 3 inch exension, and small hands. lol
Rick
Old Aug 27, 2006 | 12:38 AM
Zonomar's Avatar
Which screw does what clockwise/counter may be the question ?
Old Aug 27, 2006 | 10:55 AM
hardtocope's Avatar
the 10mm and 3inch extension is for the high beams.... they are very easy to adjust while in the car, now the low beams are a different question. Also does anyone know what clockwise does compared to counter? I have the two adjusting screw on the low beams screwed all the way in and they still point toward the ground.
Old Aug 28, 2006 | 01:45 AM
CobaltLT's Avatar
Well there are 2 screws for the low beams...one makes them point up and down, and the other side to side.
The screw on the very outer end of the headlights(near your fenders) makes them go up and down. With the headlights pointing at you, you want to turn the outer screw clockwhise to turn them upward.
As for side to side adjusting, I believe turning clockwhise makes them turn to the right...the same as the way you're turning the screwdriver.
Hope that helps...it takes a little bit to get them just right, but you'll get it eventually.
I don't know anything about adjusting the high-beams though, I have yet to do that, but I rarely use mine anyway.
Old Aug 28, 2006 | 09:33 AM
celicacobalt's Avatar
so then are we gonna have to take the headlight out of the car to adjust the low beams?
Old Sep 1, 2006 | 03:19 PM
CobaltLT's Avatar
Yes, you can't adjust them while they're mounted on the car...they have to be removed...its nothing difficult really.
Old Sep 8, 2006 | 08:29 PM
hardtocope's Avatar
i've adjusted my headlights so they are lot better than then before.. but the only problem is i think i've adjusted my lights a little to high. Do you think i will be blinding people with the low beams if there adjusted to high? Doesn't the projector help stop that?
Old Sep 8, 2006 | 08:32 PM
bavoose's Avatar
ok are they the screws that are where u put the bulb or lower than that those screws?
Old Sep 8, 2006 | 09:34 PM
hardtocope's Avatar
they are two big screws under the projectors
Old Sep 8, 2006 | 09:39 PM
bavoose's Avatar
what do you do to the screws to adjust them up and down?????????
Old Sep 10, 2006 | 11:24 PM
its pretty easy all you do is left turn to make them go up and right turn to make them go down but you have to turn both screws behind the headlight the same number of times/
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
justinchinn
Oct 2, 2015 12:18 PM
